10-06-2007, 08:33 PM
UbuntuUser
Auto on/off PC. Is that possible?
Recently a friend of mine told me that if I connect the serial port of my PC to the serial port of my UPS, then by configuring some windows scheduling services my PC will shut down after only 5% of the battery power remains in case of any power failure!
I dont know if that is possible in windows but if it then I wanna ask whether it is possible in ubuntu too??? If yes, then please either tell me or provide me with any link to do it.
And is there any way to automatic start the PC if the current comes in the socket in which I have plugged in the UPS.
The latter query is kinda absurd but even if the former works then please tell me how to do that.
11-06-2007, 07:34 AM
left this forum longback
Re: Auto on/off PC. Is that possible?
yes,it seems ur too lazy with computers
for ups walla system,there is a software called apcupsd.yes the same which uses usb connector,right?
Apcupsd a daemon for controlling APC UPSes
Apcupsd can be used for power mangement and controlling most of APC's UPS models on Unix and Windows machines. Apcupsd works with most of APC's Smart-UPS models as well as most simple signalling models such a Back-UPS, and BackUPS-Office. During a power failure, apcupsd will inform the users about the power failure and that a shutdown may occur. If power is not restored, a system shutdown will follow when the battery is exhausted, a timeout (seconds) expires, or runtime expires based on internal APC calculations determined by power consumption rates. Apcupsd is licensed under the GPL version 2.
http://www.apcupsd.org/
these packages may be available already in synaptic(apt) so dont go compiling from source.also it may need to run some cron jobs too.
if with Ubuntu,i found a nice howto:  and GIYF
http://ubuntuforums.org/showthread.php?t=114748
http://linuxappfinder.com/package/apcupsd
11-06-2007, 07:58 AM
UbuntuUser
^^Thanks man.
But there's a little problem. I think my ups has only a serial port (no usb)
Hey but can anybody help me with my UPS. It came with my Compaq PC and has "UPS AVR 500" written on the front.
In the rear part the model # is written as CQ500 (I think CQ means compaq).
I even tried searching APC's site but doesnt show any UPS like I have
So is their any way I can find what type is my UPS (BackUPS or USB thingy)
Reason: Automerged Doublepost
11-06-2007, 09:10 AM
Still Shining!
You cannot turn on a computer automatically from Shutdown state.
But if you keep the system in hibernation mode, then its posible to wake up or shutdown/hibernate the system automatically at a scheduled time. There are softwares available for it(its or Windows, I don't know for linux).
You can design a device which senses the power availability and automatically presses the power button by a mechanical hand.
Nokia N86 8MP
11-06-2007, 09:42 AM
Torrent Lover :)
But for that your motherboard should support the feature (Auto Startup from hibernation)....i have 810e chipset...mine doesnt
11-06-2007, 10:03 AM
@dynosure:
ur wanted program is upsd
http://www.boutell.com/lsm/lsmbyid.cgi/001767
upsd: UPS Monitor Program Upsd is a UPS monitor program. It supports both local monitoring of a UPS that is directly connected to the computer's serial port and remote monitoring over a network. Remote monitoring is done by polling the master upsd (the one with the direct serial connection to the UPS). There are a number of options to control the poll interval and the delay before shutdown.
another one is powstatd:
Description: Configurable UPS monitoring daemon
Assuming you have a relay-based "dumb" UPS that corresponds with your
machine via a serial connection, you should be able to configure powstatd
in just a few minutes. It is easily configured, and can be expected to
support most "dumb" UPS supplies.
UPS models known to work:
CyberPower PowerSL series
CyberPower Power2000 1500VA
CyberPower Power99 325VA, 400VA, 500VA and 720VA
Some older CyberPower 385VA and 450VA models
TrippLite Internet Office 500 UPS
Various older APC units.
Powstatd can also be configured to allow a master machine to control
(Via a network connection) up to 20 (by default) additional slave
machines connected to the same UPS. This allows you to run several
machines off the same UPS, with only one of the machines actually
reading the UPS status over the serial line. This version of powstatd
uses secure cryptography to communicate between master and slave(s),
replacing the older powstatd-crypt Debian package.
supported in GNU/Linux already.in Ubuntu too.u can refer http://ubuntuforums.org
11-06-2007, 06:19 PM
UbuntuUser
Thanks guys.
Will try this and then I'll let you know.
@praka123: Man youre a hero!!
11-06-2007, 06:28 PM
You can connect Serial Port (9 pin) to USB using Serial-USB converter available in the market costing Rs. 800. I have one but i used it for something which i don't remember that too in XP. But i have never tried in Linux.
KDE on ArchLinux
11-06-2007, 06:33 PM
UbuntuUser
11-06-2007, 07:20 PM
NP : Crysis
^^nothing, just ur ups battery will drain out. its not gud for the ups though. it'll charge but it mustn't happen often or ur batt will konk out
12-06-2007, 03:19 PM
Originally Posted by cynosure
That converter converts RS-232 to USB interface.
See this connector:
and
This is what the cable i meant:
KDE on ArchLinux
