Old 10-06-2007, 02:26 PM   #1 (permalink)
blackleopard92's Avatar
Default monitor resolution, totem HW acc, and NTFS read/write
three problems.
1. i have a 15 inch monitor, however ubuntu defaults to 1024x768 at 50hz!! that's waay too low. i wanted to run it at 800x600 at 85hz atleast but it doesn't have an option for it. max refresh rate is 59 for 800x600 and 54 for 1024x768. this really hurts eyes. any suggestions???
i run my XP at 800x600 at 85 hz.
(this is really putting me off from using ubuntu)
and one more thing, how is ubuntu's support for DVI-17inch monitors?
2. does totem have HW acc? wanted to put my 7300GT to good use
3. i found , by default NTFS support in ubuntu is read only. so searching the SPM, i found the ntfs-3g driver. further reading suggested that it can corrupt the ntfs partitions. does anybody use it? would love feedback.
oh, one more thing, is there a GUI for cron?
blackleopard92 is offline
Old 10-06-2007, 02:28 PM   #2 (permalink)
The Unknown's Avatar
Default Re: monitor resolution, totem HW acc, and NTFS read/write
Pehle din hi musibat??
KDE on ArchLinux
The Unknown is offline
Old 10-06-2007, 02:38 PM   #3 (permalink)
resolution thing is really bugging me.. can't look at monitor for long.. i site for 6-7 hrs on my computer after all
Old 10-06-2007, 02:43 PM   #4 (permalink)
For me 1024x768 is the best else i can't do my work even for 1 hr. I too sit computing for 5-6 hrs.
KDE on ArchLinux
Old 10-06-2007, 02:48 PM   #5 (permalink)
it depends on your monitor. basically 85hz is what everyone targets in CRT, and 60hz in LCD
Old 10-06-2007, 02:53 PM   #6 (permalink)
MMO Addict
amitava82's Avatar
for GFX card. you need to install driver. Use Envy script. get it from here http://albertomilone.com/nvidia_scripts1.html
After installing you will be able to set resolution, HW acceleration etc.
for NTFS read write install ntfs-3g and ntfs-config using synaptic. And its completely stable.
Steam Profile || Personal Page
Warp drive active. Approaching stargate.
amitava82 is offline
Old 10-06-2007, 03:13 PM   #7 (permalink)
My PC is older than yours. I have TVM CRT 15" @ 60 Hz and P3 500Mhz.
KDE on ArchLinux
Old 10-06-2007, 03:13 PM   #8 (permalink)
left this forum longback
praka123's Avatar
Smile Re: monitor resolution, totem HW acc, and NTFS read/write
@blackperd:
Oh yeah!u got Nvidia 7300 GT too ! I too running on a brand new XFX 7300GT dual dvi out (modelV-T73E-UDJ3 fyi!)
so u dont have 3 D acceleration(video/gfx)
u need to install nvidia drivers.its very easy in Ubuntu Feisty.what worked for me is I :
apt-get install restricted-manager
now goto menu System>Admin>restricted manager>tick nvidia gfx driver that will do!
yeah:i got extra repos added to my /etc/apt/sources.list
for ur first problem,u can go to menu System>Preferences>Screen REsolution to set ur needed one.
if that doesnt work, u need to edit /etc/X11/xorg.conf as admin(root user or sudo)
ntfs-3g allows read write access of ur ntfs partns.it is very much safe.dont fret reg that.
check menu System>admin>synaptic
may be i'll post my /etc/apt/sources.list later
praka123 is offline
Old 10-06-2007, 05:05 PM   #9 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
For NTFS-3g, do sudo apt-get install ntfs-config and then find it in applications->system tools. Just check both the checkboxes
kalpik is offline
Old 10-06-2007, 08:54 PM   #10 (permalink)
Originally Posted by praka123
@blackperd:
u guys got me wrong. i alreadt have done what praka has posted about. what i wanted to enquire was whether totem (or an video player) used HW acc for improving video qualtity, like Directx HW is used in Windows.
screen resolution doesn't show the right values. will try editing xorg.conf.
btw, what is xorg.conf used for?
Old 11-06-2007, 07:23 AM   #11 (permalink)
praka123's Avatar
Smile yes!
I suppose u dont get me right.if u had 3 D acceleration(yes,hardware acceleration) with NVIDIA cards,u may need to edit /etc/X11/xorg.conf device to "nvidia".now just follow these things.I have the same card as urs.
/etc/X11/xorg.conf explanation here:
http://en.wikipedia.org/wiki/Xorg.conf
open a terminal(menu Applications>Accessories>Terminal) and run below commands:
:~$ sudo cp /etc/X11/xorg.conf  /etc/X11/xorg.conf.bked
Now,
Open run dialog by pressing keyboard ALT+F2.insert below lines and press enter.if prompted give ur password as it require admin level to edit these files
gksudo gedit /etc/X11/xorg.conf
Now clear the contents(press CTRL+A,delete) of the editor and paste below lines:
# xorg.conf (xorg X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the xorg.conf manual page.
# (Type "man xorg.conf" at the shell prompt.)
# This file is automatically updated on xserver-xorg package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xorg
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following command:
#   sudo dpkg-reconfigure -phigh xserver-xorg
Section "Files"
        FontPath     "unix/:7100"
        FontPath     "unix/:7101"
        RgbPath      "/usr/X11R6/lib/X11/rgb"
# if the local font server has problems, we can fall back on these
    FontPath    "/usr/lib/X11/fonts/misc"
    FontPath    "/usr/lib/X11/fonts/cyrillic"
    FontPath    "/usr/lib/X11/fonts/100dpi/:unscaled"
    FontPath    "/usr/lib/X11/fonts/75dpi/:unscaled"
    FontPath    "/usr/lib/X11/fonts/Type1"
    FontPath    "/usr/lib/X11/fonts/CID"
    FontPath    "/usr/lib/X11/fonts/100dpi"
    FontPath    "/usr/lib/X11/fonts/75dpi"
  # path to defoma fonts
        FontPath     "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
        FontPath     "/var/lib/defoma/x-ttcidfont-conf.d/dirs/CID"
EndSection
Section "Module"
        Load    "dbe"
        Load    "glx"
        Load    "ddc"
        Load    "extmod"
        Load    "type1"
        Load    "freetype"
        Load    "bitmap"
        Load    "int10"
        Load    "vbe"
EndSection
Section "InputDevice"
        Identifier      "Generic Keyboard"
        Driver          "kbd"
        Option          "CoreKeyboard"
        Option          "XkbRules"      "xorg"
        Option          "XkbModel"      "pc104"
        Option          "XkbLayout"     "us"
EndSection
        Identifier      "Configured Mouse"
        Driver          "mouse"
        Option          "CorePointer"
        Option          "Device"                "/dev/input/mice"
        Option          "Protocol"              "ExplorerPS/2"
        Option          "Emulate3Buttons"       "true"
EndSection
Section "ServerFlags"
    Option         "Xinerama" "0"
EndSection
Section "Device"
        Identifier      "nVidia Corporation G70 [GeForce 7300 GT]"
        Driver          "nvidia"
        BusID           "PCI:1:0:0"
        Option "XAANoOffscreenPixmaps" "true"
        Option "AllowGLXWithComposite" "true"
        Option "AllowDDCCI" "True"
        Option "NoLogo" "True"
        Option "RenderAccel" "True"
        Option "TripleBuffer"   "true"
EndSection
Section "Extensions"
        Option "Composite" "enable"
EndSection
Section "Monitor"
        Identifier      "S/T 57/56E/V"
        Option          "DPMS"
        HorizSync       30-55
        VertRefresh     50-120
EndSection
Section "Screen"
        Identifier      "Default Screen"
        Device          "nVidia Corporation G70 [GeForce 7300 GT]"
        Option "AddARGBGLXVisuals" "True"
        Option "DisableGLXRootClipping" "true"
        Monitor         "S/T 57/56E/V"
        DefaultDepth    24
        SubSection "Display"
                Depth           16
                Modes           "1024x768" "800x600" "640x480"
        EndSubSection
                Depth           24
                Modes           "800x600"
        EndSubSection
EndSection
Section "ServerLayout"
        Identifier      "Default Layout"
        Screen          "Default Screen"
        InputDevice     "Generic Keyboard"
        InputDevice     "Configured Mouse"
EndSection
^do carefully copy(CTRL-C,CTRL-V)
My monitor is a samtron 56V(15") with max resolution @ 800x600@85Hz or 1024x768@60Hz,I prefered @85Hz one.
what is ur needed monitor resolution,which make?post here.
refer ur monitor manual/website what is the horizontal and vertical freq limit used/preferred.if ddcprobe detected ur monitor correct in xorg.conf dont do anything.if something ur confuesed post here.
make sure in restricted manager that nvidia is enabled.
regarding ur second problem,u need /etc/apt/sources.list enabled.do edit ur /etc/apt/sources.list or copy mine after making a backup.paste below lines after the ubuntu CD lines.
# # If you get GPG errors with this sources.list, locate the GPG key in this file
# # and run these commands (where KEY is replaced with that key)
# # gpg --keyserver hkp://subkeys.pgp.net --recv-keys KEY
# # gpg --export --armor KEY | sudo apt-key add -
#Ubuntu Security
deb http://archive.ubuntu.com/ubuntu/ feisty-security main restricted
deb-src http://archive.ubuntu.com/ubuntu/ feisty-security main restricted
deb http://archive.ubuntu.com/ubuntu/ feisty-security universe
deb-src http://archive.ubuntu.com/ubuntu/ feisty-security universe
deb http://archive.ubuntu.com/ubuntu/ feisty-security multiverse
deb-src http://archive.ubuntu.com/ubuntu/ feisty-security multiverse
# # Ubuntu supported packages
# # GPG key: 437D05B5
deb http://archive.ubuntu.com/ubuntu/ feisty main restricted
deb-src http://archive.ubuntu.com/ubuntu/ feisty main restricted
deb http://archive.ubuntu.com/ubuntu/ feisty-updates main restricted
deb-src http://archive.ubuntu.com/ubuntu/ feisty-updates main restricted
# # Ubuntu community supported packages
deb http://archive.ubuntu.com/ubuntu/ feisty universe multiverse
deb-src http://archive.ubuntu.com/ubuntu/ feisty universe multiverse
deb http://archive.ubuntu.com/ubuntu/ feisty-updates universe multiverse
deb-src http://archive.ubuntu.com/ubuntu/ feisty-updates universe multiverse
# # Ubuntu backports project
deb http://archive.ubuntu.com/ubuntu/ feisty-backports main restricted universe multiverse
deb-src http://archive.ubuntu.com/ubuntu/ feisty-backports main restricted universe multiverse
#### Proposed Multiverse ####
deb http://archive.ubuntu.com/ubuntu/ feisty-proposed main restricted universe multiverse
deb-src http://archive.ubuntu.com/ubuntu/ feisty-proposed main restricted universe multiverse
#### Canonical Commercial ####
deb http://archive.canonical.com/ubuntu feisty-commercial main
deb http://medibuntu.sos-sts.com/repo/ feisty free non-free
Now open synaptic pkg manager(menu System>admin>synaptic) and press reload or from terminal "sudo apt-get update".
U need to install package updates weekly, else update-manager will prompt for u @ top panel of ur GNOME desktop.
praka123 is offline
Old 11-06-2007, 09:30 AM   #12 (permalink)
mine is samtron 55v. i too need 800x600@85hz, but it is listed as generic monitor. gonna try it though.
edit: great it works! no more flickering although the fonts are a little too big, no problems here.
btw, which app to use for scheduling uses? any gui for cron?
Old 11-06-2007, 09:41 AM   #13 (permalink)
praka123's Avatar
^ the same config works for u-no change at all needed as Samtron 55/56V almost the same.
I am running @ 800x600@85 though 1024x768 also possible.the xorg.conf which i put will default @ 800x600@85
TRY it now
Edit:I forgot to tell that i use xfontserver and xtruetype font server.so pls look at edited xorg.conf @ post no: 11
I want to tell that after u got display,it will be a good idea to install packages "xfs" and "xfstt" "msttcorefonts"
sudo apt-get install xfs xfstt msttcorefonts
after that go to menu System>preferences>Fonts and set microsoft fonts for ur apps as they are better.if u can,install tahoma(license restricted) font too.
from synaptic package manager.
also go to firefox edit>preferences>Content to set corefonts as they display better and give good anti-aliasing(in windows they calls "clear type")
http://ubuntu.wordpress.com/2005/09/...crosoft-fonts/
http://www.linux.com/howtos/TT-Debian-3.shtml
http://www.linux.org/docs/ldp/howto/Font-HOWTO/fix.html
http://tldp.org/HOWTO/Font-HOWTO/
refer http://ubuntuguide.org
for such tips.
praka123 is offline
ntfs read / write in dos ashfame QnA (read only) 4 29-05-2007 04:29 PM
Can Read But cannot Write Manshahia Open Source 66 21-02-2007 11:39 AM
Mount NTFS partions as read/write gary4gar Open Source 5 26-07-2006 09:18 AM
Write in Ntfs............ khattam_ QnA (read only) 1 22-04-2005 11:18 AM
- by soumya
