Old 10-06-2007, 08:18 AM   #1 (permalink)
hrushij's Avatar
Exclamation problem in ubuntu 7.04 for PC
I have just received my new ubuntu package...
But the newer verson '7.04 for PC' is noworking on either my PC or laptop even though it has well kown hardwares and 1 gb ram...
it stops at the starting of gui screen...which make colors...on the screen like screen saver...!!!
what is the problem...??
HHJobanputra
hrushij is offline
Old 10-06-2007, 08:37 AM   #2 (permalink)
left this forum longback
praka123's Avatar
Default Re: problem in ubuntu 7.04 for PC
display resolution may not be correct.press CTRL+ALT+F1 to get a VTE and login.u may need to edit ur /etc/X11/xorg.conf to get a satisfiable display.also post ur graphics card,mobo details.
praka123 is offline
Old 13-06-2007, 06:53 AM   #3 (permalink)
hrushij's Avatar
Nvidia Motherboard+64mb Graphics Card With 212 Mb Shared Memory From 2 Gb Ram. And Processor 2x64 Bit Turion..ok
Thank You
HHJobanputra
hrushij is offline
Old 13-06-2007, 11:00 AM   #4 (permalink)
praka123's Avatar
Smile NVIDIA card no driver
I suppose u r in a live-cd and u dont get GUI.
I suppose ur graphics card also is nvidia make.nvidia gfx cards needs drivers either open source "nv" or proprietory "nvidia".so when the garbled colour screen appears,just press keyboard keys CTRL+ALT+F1 to get a vte.if there is "#" prompt already there,we can proceed.else
oh,now u need a username to login.hmm..for that login as ubuntu and passwd may be ubuntu too.I'll check and post here soon.
Now to the problem,
U need to edit the /etc/X11/xorg.conf to set driver as "vesa"
the editor used is "nano" it is easy to use.go to section "Device" and edit the
 Driver          "vesa"
save by pressing CTRL+O(letter) and exit by CTRL+X.now in the terminal type
~#/etc/init.d/gdm restart
^in linux and unix space must be respected
praka123 is offline
Old 19-06-2007, 07:24 AM   #5 (permalink)
hrushij's Avatar
thx but i dont hv any problem in earlier versions....of Ubuntu..
HHJobanputra
hrushij is offline
Old 19-06-2007, 08:55 AM   #6 (permalink)
praka123's Avatar
Smile Re: problem in ubuntu 7.04 for PC
yeah.that may be because open source nvidia driver "nv" detected and configured ur X(Display) correctly.may be u can configure to use "nv" as the driver here too
:~$sudo dpkg-reconfigure xserver-xorg
and select "nv" for 2D Open Source Nvidia driver or if none worked try "vesa" driver.for that "blue screen" CLI curses installer,u can select items by TAB,UP and Down arrows and Return(Enter) Keys.
praka123 is offline
ubuntu 6.06 display problem!!!! sav_more Open Source 2 19-02-2007 08:04 PM
Ubuntu + AMD problem shivkumar Open Source 3 12-11-2006 05:58 PM
problem with ubuntu shivi4 Open Source 4 09-05-2006 11:13 AM
Problem with Ubuntu drvarunmehta Open Source 11 20-06-2005 10:05 PM
UBUNTU install problem.. //siddhartha// Open Source 7 26-03-2005 07:24 AM
- by soumya
- by reddick
