Old 09-06-2007, 08:59 AM   #1 (permalink)
saurabh.sauron's Avatar
Default GRUB problem in triple booting
I installed Fedora 7, Ubuntu 7.04 and Windows XP. The GRUB is of Ubuntu and Fedora does not boot. it returns a "Kernel Panic. Attempt to Kill INIT." error. The kernel and other packages are up to date.
Here is my menu.lst entry for Fedora (there is no grub.conf file)
title           Fedora 7
root            (hd1,0)
kernel          /boot/vmlinuz-2.6.21-1.3194.fc7 ro root=LABEL=/ rhgb quiet
initrd          /boot/initrd-2.6.21-1.3194.fc7.img
saurabh.sauron is offline
Old 09-06-2007, 09:04 AM   #2 (permalink)
left this forum longback
praka123's Avatar
Default Re: GRUB problem in triple booting
LABEL=/ may be changed?try booting with the line changed as below:
title           Fedora 7
root            (hd1,0)
kernel          /boot/vmlinuz-2.6.21-1.3194.fc7 ro root=/dev/sdb1 rhgb quiet
put the correct device file name (/dev/sdb1?)
if that too doesnt help,probably partition order changed or do u have separate /boot partn.
praka123 is offline
Old 09-06-2007, 09:13 AM   #3 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Try changing the title to just Fedora.
kalpik is offline
Old 09-06-2007, 09:16 AM   #4 (permalink)
praka123's Avatar
title has nothing to do with boot
praka123 is offline
Old 09-06-2007, 09:25 AM   #5 (permalink)
kalpik's Avatar
Naah.. But i read somewhere that it takes the 7 up as runlevel and tries to boot into runlevel 7!
Edit here: http://www.tuxmachines.org/node/16894
kalpik is offline
Old 09-06-2007, 10:31 AM   #6 (permalink)
BE FREE
what is run level 7
there is a problem with fiesy7 distro, so install fedora7 after fiesty and install grub of fedora this may solve your problem, same thing was observed on open solaris forums.
"To know that we know what we know, and to know that we do not know what we do not know, that is true knowledge." ~ Copernicus
azaad_shri75 is offline
Old 09-06-2007, 10:57 AM   #7 (permalink)
kalpik's Avatar
Runlevel 7 is non-existent! Read that link and you will know more..
kalpik is offline
Old 09-06-2007, 11:05 AM   #8 (permalink)
BE FREE
yep,I know that, offcourse I did not read through it.
Old 10-06-2007, 06:37 PM   #9 (permalink)
kalpik and praka123 were both right. actually, GRUB recognised the 7 as runlevel 7 (which doesnt exist) and tried to boot, which caused the error changing the tile to Fedora and sdb1 worked perfectly
thnx all of u for ur replies.
Old 10-06-2007, 08:08 PM   #10 (permalink)
kalpik's Avatar
Glad its solved
kalpik is offline
Triple booting. Where to install? phreak0ut Open Source 27 27-04-2007 06:46 PM
How To Configure My System For Dual Or Triple Booting ????? clmlbx Software Q&A 3 14-09-2006 09:19 PM
Triple booting XP, Vista and Ubuntu blackpearl Software Q&A 1 06-09-2006 05:06 PM
How can I make an entry in GRUB for CD/DVD booting? cool_dude_prav Open Source 1 27-07-2005 01:21 AM
- by soumya
- by reddick
