Hi. I am a Linux newbie.
I recently installed Ubuntu 7.04 on my system. Intel D945G Motherboard.
I am having some problems with display, .If i select 1024x768, the display is out of screen. Means if i move cursor to the corners, screen scrolls to reveal the remaining part of screen.
LG Studioworks 15" 52V Monitor
Rés Max 1024 x 768 (60Hz)
Dot Pitch 0,28 mm , compatible Plug and Play
Fréq : Horizontal 30 - 54 kHz
Vertical 50 - 120 kHz
If i manually add 1024x768@60hz with this modline.
# 1024x768 @ 60Hz, 47.52 kHz hsync
Mode "1024x768"
DotClock 57.40
HTimings 1024 1040 1104 1208
VTimings 768 770 772 792
EndMode
Then Vertical display is OK, but he horizontal display is out of screen.
Any thing that i can try changing in this modline to make it work ???
XP Pro works fine on 1024x768 @60Hz.
I tried everything, reconfigured xorg, manually entered Horizontal sync, vertical refresh, modlines.
please suggest any fix, or a good, cheap CRT monitor thats works fine with feisty.
