Old 24-05-2007, 12:01 PM   #1 (permalink)
Default Red Hat 8.0 Noob help
Linux noob here
i have few files to be copied from my university Lab Pc,having red hat 8.0 installed dual boot with xp,has Usb Ports & Floopy drive
wats the way for copying files to & fro either using a pen drive or a floopy
need help on this as i am noob in linux
vinyas is offline
Old 25-05-2007, 03:55 PM   #2 (permalink)
Default Re: Red Hat 8.0 Noob help
can anybody help me ?
best would be to use a pen drive ...i guess
i dont know how to mount it
help out guys
vinyas is offline
Old 25-05-2007, 04:14 PM   #3 (permalink)
String Phreak
mediator's Avatar
Insert ur pen drive, and tell the output of command "dmesg".
mediator is offline
Old 25-05-2007, 06:16 PM   #4 (permalink)
thnx mediator
sorry for my ignorance wr do u type this dmesg ? in a new terminal ?
vinyas is offline
Old 25-05-2007, 06:23 PM   #5 (permalink)
String Phreak
mediator's Avatar
Yea
mediator is offline
Old 25-05-2007, 06:51 PM   #6 (permalink)
thnx again mate
we have many people sharing the machines @ lab,people tend to delete the project files by mistake or remove on purpose
i have a folder inside which contains my project files
is thr any way to protect this ? such that it does not get listed in the LS command ?
thnx for the help people
vinyas is offline
Old 25-05-2007, 08:47 PM   #7 (permalink)
left this forum longback
praka123's Avatar
set permissions to protect ur files.
praka123 is offline
Old 25-05-2007, 09:15 PM   #8 (permalink)
thnx
is this procedure to followed ?
http://www.thinkdigit.com/forum/show...36&postcount=6
vinyas is offline
Old 25-05-2007, 10:46 PM   #9 (permalink)
String Phreak
mediator's Avatar
Yes thats the procedure. To protect ur files u can make a new account for u, where u can save ur files!
mediator is offline
Old 26-05-2007, 10:17 AM   #10 (permalink)
just for transferring files to & fro to a pendrive."dmesg" will do ?
vinyas is offline
Old 26-05-2007, 12:08 PM   #11 (permalink)
String Phreak
mediator's Avatar
Actually RH8 is very old! U shud get newer distros which automount the pendrives just like windows.
Neways, dmesg will tell to what device, like sda,sdb etc, the pendrive points at!!
mediator is offline
Noob question jatinkompelli Open Source 1 06-04-2007 01:07 AM
audio queries of a noob..help me ! gurujee Hardware Q&A 15 07-03-2007 07:21 PM
sound system queries of a noob..help me ! gurujee QnA (read only) 5 06-03-2007 07:42 PM
noob help forever Hardware Q&A 5 13-12-2006 01:27 PM
OpenOffice noob Queries..!! prasad_den Open Source 6 26-09-2006 09:34 PM
- by soumya
- by reddick
