Old 22-05-2007, 09:45 PM   #1 (permalink)
Default No sound in Linux
Hi guys... it's been a long time.... had to study for 12th std...
Anyways, here's my problem..
I have a Creative PCI sound card, in addition to the onboard sound card. I have Mandrake 10.1 installed from a DIGIT DVD. Linux detects the onboard card as SiS <some brand name> and my Creative card as Ensonique. I don't know what driver to choose and the default driver doesn't work. I had sound coming before, but I reinstalled Linux and now, I don't know what driver I used last time. Please help.....
P.S. Don't flame me for posting this in the wrong subforum, just tell me. I have been out of touch and I had to google to find this website.
Dumbledore is offline
Old 22-05-2007, 10:20 PM   #2 (permalink)
left this forum longback
praka123's Avatar
Default Re: No sound in Linux
this is the right section!
first disable ur onboard soundcard in BIOS.then try.mostly ur card will be enabled.else open a terminal as root user.try 'alsaconf' command.
terminal as root user:
in terminal(in kde,konsole),type after "$" prompt,
~$ /usr/sbin/alsaconf
^^ it will detect ur card and enable it.use kmix(in sound/multimedia menu) to adjust sound volume and properties.
if somehow alsaconf command is not available,download from mandriva website and install.I hope u already have ur internet configured on ur Linux Mandriva.
praka123 is offline
Old 22-05-2007, 10:21 PM   #3 (permalink)
String Phreak
mediator's Avatar
Check if "external amplifier" is enabled in 'switches'!
mediator is offline
Old 25-05-2007, 09:59 PM   #4 (permalink)
Thanks for your answer praka123. I'll try it and get back to you.
mediator, you talk about external amplifier and switches. I don't understand what you mean by them. Please explain.
Old 25-05-2007, 10:41 PM   #5 (permalink)
String Phreak
mediator's Avatar
1. Go to volume applet in gnome, double click it
2. Go to tab "switches" > "external amplifier"
3. check it!
mediator is offline
Old 26-05-2007, 10:05 PM   #6 (permalink)
Yes, I do have internet. But I tried alsaconf, but to no effect. Do I have to restart? I remember changing the default driver last time.
Thanks Praka123. Your solution really worked. Now I can shift completely to Linux. THANK YOU!!!!
no sound on laptop using suse 10.1 linux roxisayshi Open Source 8 28-03-2007 03:36 AM
Sound card in Linux Kalyan Hardware Q&A 1 05-11-2005 01:04 AM
not able to hear sound in linux! :( legolas Open Source 3 05-09-2005 06:51 PM
- by soumya
- by reddick
