| Forum |
#1 (permalink) |
world is evil
i installed fiesty,i tried copying some songs to ntfs drives which i created in windows,but i was unable to create any folder.copy files etc.it said you do not have permisiions. what do i do? and guys im a newbie in linux,if you give a solution then write in detail... thanks |
#2 (permalink) |
are you are trying 2 copy songs to ntfs drive from Ubuntu?
you can only read files from ntfs by default you have to install ntfs-3g Code:
sudo apt-get install ntfs-3g
"UNIX is basically a simple operating system, but you have to be a genius to understand the simplicity." -Dennis Ritchie |
#3 (permalink) |
Unable to mount NTFS Partitions
Your solution is here. I had the same problem with debian. and since ubuntu is derived from debian the solution is the same. |
#5 (permalink) |
sudo apt-get install ntfs-3g sudo apt-get install ntfs-config 1) Mount internal ntfs partitions 2) Mount external ntfs partitions. Thus, you can mount wour ntfs partitions just by 2 clicks
http://apoorvkhatreja.blogspot.com |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| STRANGE PROBLEM??? | wizrulz | Hardware Q&A | 12 | 16-03-2006 09:11 PM |
| strange problem | harshagarwal | QnA (read only) | 10 | 22-06-2005 05:21 PM |
| Strange XP Problem | mohit | QnA (read only) | 12 | 11-04-2005 10:22 PM |
| Strange! very strange..!! Where is the Problem ? | Ricky | QnA (read only) | 8 | 11-04-2005 04:14 PM |
