Old 21-05-2007, 10:48 AM   #1 (permalink)
Beware of the innocent
ilugd's Avatar
Default Not able to login to Open Suse 10.2
I am unable to login to my user account in OpenSuse 10.2. My system has been running for over 3 days continuously and i have installed quite a few softwares so i cannot pin point the reason. But I am able to login to root and any new account i create. Where can I find a log or something of the login procedure?
Also after I enter my id and password, the screen become blank (There is an about inch thick bar at the bottom seemingly a corrupted screen) for about a second or so and the login screen comes up again. I check the user home directory settings in Yast > Security and Users > User Configuration and everything is perfect. What could possibly be the problem?
Life is too short. Have fun.
ilugd is offline
Old 21-05-2007, 12:53 PM   #2 (permalink)
18 Till I Die............
Default Re: Not able to login to Open Suse 10.2
No error messages? Press ctrl+alt+F12 when you login as user and see if there's anything worth noting there.
mehulved is offline
Old 21-05-2007, 02:10 PM   #3 (permalink)
ilugd's Avatar
no message. The screen is completely blank on pressing ctrl-alt-f12 but there is a cursor blinking on the top left.
On pressing ctrl-alt-f1 i am able to l am able to login at the commandline
ilugd is offline
Old 21-05-2007, 02:36 PM   #4 (permalink)
1337 |)00|) \m/
kaustav_geek's Avatar
I'm not sure but there might be a conflicting X client in one of those accounts .... happened to me when on Sabayon ,once....
Also, have you enabled XGL ? Go through this....
My Blog : www.vatsuak.blogspot.com
My DA page : www.burningsilver.deviantart.com
OK..ok..... Ads are bad..
kaustav_geek is offline
Old 21-05-2007, 03:48 PM   #5 (permalink)
ilugd's Avatar
no luck. XGL seems to be disabled. Please help me people. I have configured that profile fully to my taste. I don't want to recreate another profile.
Hurray, works now. here is now it worked
move to the text login screen ctrl+alt+f1
1. Login as the local user
2. type ls -al on the prompt (you shud see .xinitrc there )
3. rm .xinitrc
4. exit
Then again shifted to ctrl+alt+f7 and logged in and voila! I am in.
Here is the source. http://suseforums.net/index.php?showtopic=5073
ilugd is offline
Old 21-05-2007, 06:38 PM   #6 (permalink)
Oops we didn't check that before. Maybe the owner of .xinitrc would have been changed. That would be causing problems. Anyways you got it working now.
mehulved is offline
Old 22-05-2007, 12:12 PM   #7 (permalink)
ilugd's Avatar
Thanks everyone for all your help. I am not sure how the permissions could have been changed though.
ilugd is offline
Open Suse 10.2 Query dissel Open Source 13 10-03-2007 10:30 PM
Open SuSE 10.1 update NucleusKore Tutorials 1 20-10-2006 04:11 PM
Softwares for Open SuSE nishant_nms Open Source 2 07-02-2006 11:17 PM
