Old 23-05-2007, 01:08 PM   #61 (permalink)
Evil Genius
faraaz's Avatar
Default Re: Finally Shifted!!!
Holy crap it works!!! You guys rock...you know that??!?
Okay...one more...where can I find a Dock/Widget bar applet like how you have ObjectDock for Win XP?? Preferably one which is easy to install and configure, works in PCLOS and KDE...
Roses are #FF0000, Violets are #0000FF...All of my base are belong to you!
faraaz is offline
Old 23-05-2007, 01:12 PM   #62 (permalink)
18 Till I Die............
avant navigator and also check cairo clock.
mehulved is offline
Old 23-05-2007, 10:23 PM   #63 (permalink)
Evil Genius
faraaz's Avatar
I got AWN...doesn't compile, it says I need GTK, GConf, Python dependencies etc. I opened up Synaptic and checked, I have every single dependency with correct version number installed.
WTH?!?
faraaz is offline
Old 23-05-2007, 10:28 PM   #64 (permalink)
El mooooo
eddie's Avatar
If deb's are anything like rpm's then did you install devel libraries? There should be separate packages with names suffixed with something like devel or dev. For example: gtk-devel or something like that.
Windows users shouldn't get to use the real computers. They know just enough to be dangerous.
eddie is offline
Old 23-05-2007, 10:40 PM   #65 (permalink)
left this forum longback
praka123's Avatar
yes devel package needa installed.also make sure build-essential is there.
praka123 is offline
Old 23-05-2007, 10:51 PM   #66 (permalink)
WTH?!?
Why compile?
mehulved is offline
Old 23-05-2007, 11:38 PM   #67 (permalink)
Evil Genius
faraaz's Avatar
Because its not available in PCLOS repos and only the source is available on the AWN website, no binaries...
Hmm...so if I install the devel stuff, it will install fine? Lemme get back to you on that...
Edit: Just to be sure, I have to extract source to /root and then compile right?
Edit2: Okay, I've been trying to install the Domino 0.4 theme from KDE-Look.org...and while compiling, I get this error:
checking for X... configure: error: Can't find X includes. Please check your installation and add the correct paths!
What does this mean??
Edit3: Also, how do you activate a theme in Emerald Themer 0.2.0?
faraaz is offline
Old 24-05-2007, 07:49 AM   #68 (permalink)
praka123's Avatar
PClinux OS is based on mandriva/fedora linux right?.no need to get compiling from source.get urself rpms relevent for Mandriva/fedora.also remember installing rpms or compiling from source means u need to manually install dependencies to satisfy.
PCLinuxOS maintains its own software repository, available via the Advanced Packaging Tool (APT) and its Synaptic front-end, completely replacing Mandriva's urpmi. PCLinuxOS endeavors to maintain a fully valid upgrade path for version 1.0. This means that an installation could be continuously updated to the latest versions of packages, hence foregoing the need to re-install the entire distribution upon each successive release. In the test releases before 1.0, it has sometimes been necessary to perform a reinstallation.
http://en.wikipedia.org/wiki/PCLinux...Mandriva_Linux
why dont u configure apt-4-rpm to manage packages?
http://docs.mypclinuxos.com/Synaptic
praka123 is offline
Old 24-05-2007, 10:24 AM   #69 (permalink)
Evil Genius
faraaz's Avatar
@praka123: Dude, I shifted like a week ago! I have no idea what you just said...
faraaz is offline
Old 24-05-2007, 05:27 PM   #70 (permalink)
El mooooo
eddie's Avatar
No. Firstly in normal circumstances, you should not be having access to /root directory AT ALL. Are you using your OS as root account? If yes, then please don't do that. It is not only a security loop hole but if you accidentally delete some system files then it can also cause you unnecessary annoyance.
Secondly, you should create a temp or tmp directory in your home folder and then unpack all the sources in that folder. This helps you keep your home directory clean and manageable.
You need xorg devel libraries. Look for them in the package manager of your distro.
You need to run emerald-theme-manager, then import the theme file in there and just click on theme entry.
eddie is offline
Old 25-05-2007, 01:08 PM   #71 (permalink)
praka123's Avatar
Smile Re: Finally Shifted!!!
meh?I am just trying to say that Linux distros also got package updates(remember windows update service online?).just follow the links given.
praka123 is offline
Microsoft has done it finally gxsaurav Technology News 36 06-05-2007 01:24 PM
Finally bought. slash_89 Hardware Q&A 7 25-03-2007 06:54 PM
Oblivion Is Finally Available for the PS3 Third Eye Gamerz 2 22-03-2007 09:37 PM
How many members have shifted c2d platform.. shashank4u QnA (read only) 6 10-10-2006 12:24 AM
Finally...from Intel to AMD harish_21_10 Hardware Q&A 40 29-10-2005 09:21 AM
- by soumya
- by reddick
