Old 19-05-2007, 05:12 PM   #1 (permalink)
AJJU
azzu's Avatar
Default mandriva installation problems
iam tryin to install mandriva i already have xp installed on my comp want dual boot
i booted mandriva dvd and started intallation after selecting the language security level ,selecting drive ,formating drive ,an option asking something like multmedia ....gnome....etc.came and i selcted all and after that its say not enoug space to continue installation i think u already guessed that iam novice
HELP ME
I love and Live to Design
azzu is online now
Old 19-05-2007, 05:21 PM   #2 (permalink)
rohus24's Avatar
Default Re: mandriva installation problems
check if u have enuf space on ur partitions
u might need 4 gb space atleast
rohus24 is offline
Old 19-05-2007, 05:23 PM   #3 (permalink)
AJJU
azzu's Avatar
I HAVE 18GB ON MY PARTITION is it enough????
some one HELP ME PLZZZ
azzu is online now
Old 19-05-2007, 06:15 PM   #4 (permalink)
1337 |)00|) \m/
kaustav_geek's Avatar
Yeah, its more than enough for the full installation at least... Are you sure that the partition that you are installing Mandriva on has 18GB space ?
My Blog : www.vatsuak.blogspot.com
My DA page : www.burningsilver.deviantart.com
OK..ok..... Ads are bad..
kaustav_geek is offline
Old 19-05-2007, 08:53 PM   #5 (permalink)
18 Till I Die............
Can you list your partition layout, and did you make the partitions manually or automatically?
mehulved is offline
Maya 8.0 installation problems :( deepak.krishnan Software Q&A 8 23-04-2007 02:40 PM
Ubuntu Installation Problems adit_sen Open Source 13 10-08-2006 11:52 PM
Problems in installing Mandriva Linux 2006 thechamp Open Source 4 06-07-2006 09:04 PM
Partion and Audio problems in Mandriva linux :? baccilus Open Source 78 09-04-2006 09:13 PM
Problems during PCQ installation. IG Open Source 7 23-12-2004 11:43 AM
