Old 19-05-2007, 01:47 PM   #1 (permalink)
sachin_kothari's Avatar
Unhappy Unable to mount NTFS Partitions
I am using Debian 4. I am facing this wierd problem. Whenever i try yo mount my windows partitions(ntfs) i receive the following error message. How do i go about it?
Unable to mount the selected volume.:
libhal-storage.c 1401 : info: called libhal_free_dbus_error but dbuserror was not set.
process 9701: applications must not close shared connections - see dbus_connection_close() docs. this is a bug in the application.
error: device /dev/hda5 is not removable
error: could not execute pmount
I am able to view partitions(ntfs) from my external hard disk, but not from my main hard disk.
sachin_kothari is offline
Old 19-05-2007, 02:13 PM   #2 (permalink)
El mooooo
eddie's Avatar
Default Re: Unable to mount NTFS Partitions
How are you trying to mount your partitions? You need to add the entries in your fstab. Have you done that? If yes then post the contents of your /etc/fstab and /etc/mtab files.
Windows users shouldn't get to use the real computers. They know just enough to be dangerous.
eddie is offline
Old 19-05-2007, 04:16 PM   #3 (permalink)
i am just double clicking the drives in My Computer.
thats how i use my external hdd partitions.
i dont know what entries are to be made in /etc/fstab.
actually i am a newbie in linux. so dont know much about it.
Also i cannot write to the external hdd partitions. it is read only.
ok, i somehow managed to insert the lines in /etc/fstab.
now i am able to access all my partitions.
but i still cant write to them.
here is my /etc/fstab file
# /etc/fstab: static file system information.
# <file system> <mount point> <type> <options> <dump> <pass>
proc /proc proc defaults 0 0
/dev/hda9 / ext3 defaults,errors=remount-ro 0 1
/dev/hda10 none swap sw 0 0
/dev/hdd /media/cdrom0 udf,iso9660 user,noauto 0 0
/dev/fd0 /media/floppy0 auto rw,user,noauto 0 0
/dev/hda1 /mnt/XP ntfs rw,user,umask=000 0 0
/dev/hda5 /mnt/VISTA ntfs rw,user,umask=000 0 0
/dev/hda6 /mnt/DOWNLOADS ntfs rw,user,umask=000 0 0
/dev/hda7 /mnt/JUNK ntfs rw,user,umask=000 0 0
/dev/hda8 /mnt/ENTERTAINMENT ntfs rw,user,umask=000 0 0
Last edited by sachin_kothari; 19-05-2007 at 04:38 PM. Reason: Automerged Doublepost
Old 19-05-2007, 04:24 PM   #4 (permalink)
El mooooo
eddie's Avatar
You need to install ntfs-3g package from your package manager and then at every place where it says "ntfs"...replace it with ntfs-3g
eddie is offline
Old 19-05-2007, 04:34 PM   #5 (permalink)
I downloaded the ntfs-3g package from http://packages.debian.org/unstable/otherosfs/ntfs-3g
but while installing i got this message.
pkg -i '///home/sachin/ntfs-3g_1.516-1_i386.deb' ;echo RESULT=$?
dpkg: status database area is locked by another process
RESULT=2
Old 19-05-2007, 04:48 PM   #6 (permalink)
18 Till I Die............
Do we need that now, with HAL and pmount around?
Why don't you use apt or aptitude?
mehulved is offline
Old 19-05-2007, 04:51 PM   #7 (permalink)
Using apt gave me this message
E: Could not get lock /var/lib/dpkg/lock - open (11 Resource temporarily unavailable)
E: Unable to lock the administration directory (/var/lib/dpkg/), is another process using it?
Old 19-05-2007, 04:54 PM   #8 (permalink)
What else is running? Some other instane of apt or aptitude or synaptic or some updates?
mehulved is offline
Old 19-05-2007, 05:13 PM   #9 (permalink)
konqueror
JuK.
thats it.
ok, i found out.
i closed all applications and run the installer again.
it tells that some packages (fuse) are old and i need the new version (2.6.5)
i downloaded that from sourceforge, but how do i compile that.
i have no idea about compiling.
Last edited by sachin_kothari; 19-05-2007 at 05:13 PM. Reason: Automerged Doublepost
Old 19-05-2007, 05:39 PM   #10 (permalink)
1337 |)00|) \m/
kaustav_geek's Avatar
Check this ... A very detailed how to..
My Blog : www.vatsuak.blogspot.com
My DA page : www.burningsilver.deviantart.com
OK..ok..... Ads are bad..
kaustav_geek is offline
Old 19-05-2007, 05:59 PM   #11 (permalink)
i downloaded all the packages required and installed ntfs-3g.
and then as eddie said replaced "ntfs" with "ntfs-3g" and restarted.
now when i clicked on the partitions, they are gone.
what happened?
here's my /etc/fstab file
/dev/hda1 /mnt/XP ntfs-3g rw,user,umask=000 0 0
/dev/hda5 /mnt/VISTA ntfs-3g rw,user,umask=000 0 0
/dev/hda6 /mnt/DOWNLOADS ntfs-3g rw,user,umask=000 0 0
/dev/hda7 /mnt/JUNK ntfs-3g rw,user,umask=000 0 0
/dev/hda8 /mnt/ENTERTAINMENT ntfs-3g rw,user,umask=000 0 0
i suppose i forgot a new line at the end of file.
anyway, that above problem is solved.
but, now when i click on my partitions it says "Malformed URL"
what does that means?
Last edited by sachin_kothari; 19-05-2007 at 05:59 PM. Reason: Automerged Doublepost
Old 19-05-2007, 06:35 PM   #12 (permalink)
El mooooo
eddie's Avatar
AFAIK HAL handles removable devices...not the partitions on your hard drive.
Where are you clicking these partitions? You need to go to to /mnt directory and there all your mounted partitions are. If it still doesn't solve...post the contents of /etc/mtab.
eddie is offline
Old 19-05-2007, 06:55 PM   #13 (permalink)
thanks everyone.
finally managed to get through.
i was checking in /media, but as u said it is in /mnt directory.
thanks a lot for bearing with my silly mistakes.
Old 19-05-2007, 07:08 PM   #14 (permalink)
left this forum longback
praka123's Avatar
ohh..i came late.U can use Synaptic package manager to install packages.
^^ this is coz apt-get is already working.so
~#killall -9 apt-get
is ur option if u really wants.
praka123 is offline
Old 19-05-2007, 07:12 PM   #15 (permalink)
i closed all the running applications and that did solved my problem while installing ntfs-3g packages.
Old 19-05-2007, 07:45 PM   #16 (permalink)
praka123's Avatar
^^ that error u got was not becoz of running konqueror,but due to some way apt-get is working earlier.
praka123 is offline
How to mount NTFS partition in Ubuntu DeSmOnD dAvId Open Source 53 24-08-2007 01:54 AM
Mount NTFS in Ubuntu nishant_nms Open Source 4 07-12-2005 02:46 PM
Mount FAT Partitions in Redhat 9 mohanty1942 QnA (read only) 4 14-02-2005 09:29 PM
Unable to mount all ntfs drives in fedora3.mount one ntfs, neerajvohra Open Source 1 06-02-2005 03:56 PM
How To mount ntfs in fedora core 3 neerajvohra Open Source 6 27-01-2005 04:03 PM
