| Forum |
#1 (permalink) |
Does anyone know why it might be hissing so much? The hissing does go away if I turn the volume down from the speaker, but even with the volume turned all the way up from the software, it is still VERY quiet. Any help would be greatly appreciated. |
#2 (permalink) |
1337 |)00|) \m/
I suppose that 'Line in' or 'CD' or the like sources are also enabled as output.. Try unchecking them from the sound mixer.......
My Blog : www.vatsuak.blogspot.com My DA page : www.burningsilver.deviantart.com OK..ok..... Ads are bad.. |
#5 (permalink) |
El mooooo
Then it should be your mic. Either you mic is connected to your system with mic volumes turned all the way up or your jack is some how receiving static. Check in your volume levels and mute the mic.
Windows users shouldn't get to use the real computers. They know just enough to be dangerous. |
#6 (permalink) |
String Phreak
What I have noticed is that the hissing noise is there if u increase the PCM level or enable the line in or the MICROPHONE. Its irrelevant if its linux or Xp cause its there in both of them.
So try exploring the sound options and check if mic is enabled!
Bad Bad server.....No candy for u! |
#8 (permalink) | |
String Phreak
Also u may make surround Jack mode => shared. I forgot wat its for, but I made it like that in my profile long time back.
#9 (permalink) | |
#10 (permalink) |
String Phreak
Just explore or post it in ubuntuforums.org. Actually that shared thing is in fedora. I'm sorry for that! I'll tell again wheneva I will have access to ubuntu.
#11 (permalink) | |
#12 (permalink) |
left this forum longback
First of All,all those options mic,LFE,surround etc are not visible by default.open gnome volume control ..>Edit tab>Preferences>tick those wanted.now see the options in main window.u should disable mic options.try playing with other options too to get desired sound quality.
left this forum long back.Admin Can Delete this Account and posts Permanantly.Thank You Get GNU/Linux - http://getgnulinux.org |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| fan noise problem | abhishek_sharma | Hardware Q&A | 3 | 06-04-2007 12:27 PM |
| Nokia N73 ME Headset hissing noise.. | Rockstar11 | Mobiles and Tablets | 7 | 19-02-2007 10:40 PM |
| Hissing Sound/Disturbance Coming From Speakers/Sound Card ! | mikeon | Audio | 8 | 15-10-2006 10:37 AM |
| Loud Noise from PC-help | CT Squad | Hardware Q&A | 3 | 02-07-2006 07:15 PM |
| louder Hissing Sound while song Paused | dabster | QnA (read only) | 2 | 18-11-2005 04:55 PM |
