Old 15-05-2007, 09:28 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Smile How To Connect Adsl 220bx Beetel Modem
iam using redhat 9.0 ,iam unable to configure my broadband modem {adsl 220bx beetel modem}, how to configure it via usb
asdfgh2 is offline
Old 15-05-2007, 09:31 PM   #2 (permalink)
left this forum longback
praka123's Avatar
Default Re: How To Connect Adsl 220bx Beetel Modem
usb adsl is 99% not possible,if possible also unstable.get a lan card.try pppoe connxn
praka123 is offline
Old 15-05-2007, 10:48 PM   #3 (permalink)
sachin_kothari's Avatar
i previously used usb, but lan is more convenient.
sachin_kothari is offline
Old 15-05-2007, 10:54 PM   #4 (permalink)
UbuntuUser
cynosure's Avatar
^^ I am using ADSL with USB but in ubuntu from the last september. No problems till now.
@asdfgh2: Assuming that the basic linux are all same. Use this script:
Make a new file anywhere (on the desktop maybe)
[Desktop Entry]
Name=RP-PPPoE
Comment=RP-PPPoE
Exec=gksudo /opt/rp-pppoe-3.6/go-gui
Icon=pppoeconf.xpm
Terminal=false
Type=Application
Categories=Application;Network;
SAve the file and click on it.
Run: Applications -> Internet -> RP-PPPoE
THis worked fine in ubuntu 6.06. I cont guarantee that this will work fine in RH. Anyways Best Of Luck.
cynosure is offline
Old 15-05-2007, 11:31 PM   #5 (permalink)
praka123's Avatar
^^ already rp-pppoe is there in Ubuntu!
run : sudo pppoeconf.
I think as per ur suggestion,u have extracted rp-pppoe source from their site.now what is the use,when debian's(ubuntu's) package manager already lists packages such as pppoe,pppoeconf,eciadsl(usb modem drivers) and more
praka123 is offline
Old 16-05-2007, 08:24 AM   #6 (permalink)
UbuntuUser
cynosure's Avatar
Look brother. Your avatar shows that you know most of things about linux.
Terminal is still a nono for me so I know nothing about those commands..
I am still a mortal in front of you. So I tried giving him what worked for me!!
If that works for him then its fine.
Nothing to offend you. Take this lightly. again!!
cynosure is offline
Old 21-11-2007, 09:46 PM   #7 (permalink)
Unhappy Re: How To Connect Adsl 220bx Beetel Modem
Hi,
I read what you had given with great interest. I am a Linux newbie adn had heard and read much about ubuntu. So I wanted to try it and dual booted my winxp pro with ubuntu 7.10 (installed on two separate hard disks).
Before the instllation I tried with a livecd and for one time my beetel adsl2 modem on ethernet worked. Heatrened, I installed ubuntu on hard disk.
From then on I have struggled without any success in connecting to the internet - which was my main purpose for ubuntu till i get used to it.
On winxp ii use raspppoe dialler to connect and supply my login and password each time. I heve the no download limit plan so i am not billed for the time.
i have read on the net extensively, some people have been lucky with this modem on various distros of linux. I have not - and am getting frustrated enough to think discarding linux. I have tried ubuntu, Damn Small Linux, Knoppix on either live cd or usb stick but could not connect.
I see from your efforts that you have succeeded.
Is it possible for you to guide me step by step what to do?
Thanks
SK Goel
[Desktop Entry]
Name=RP-PPPoE
Comment=RP-PPPoE
Icon=pppoeconf.xpm
Terminal=false
Type=Application
skgoel is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/open-source/57869-how-connect-adsl-220bx-beetel-modem.html
Help! Beetel 220BX connectivity problems - Ubuntu Forums This thread Refback 08-09-2010 01:51 AM
Configuring beetel 220bx adsl2modem for port forwarding suhas.m Software Q&A 2 19-11-2006 10:43 PM
