Old 10-05-2007, 10:30 PM   #1 (permalink)
"The Gentleman"
vish786's Avatar
Post mounting sata drive & pen drive
does anyone know how to mount sata hdd which is in NTFS format tat too in WRITEABLE mode so tat file can be transferred from c drive to other logical drive....
How to mount an USB Pen Drive
Attach your USB pendrive to Linux computer.
#dmesg
{Check the last lines. It will show the device name used by pendrive for example
/dev/sda1 or /dev/sdb1)
#mkdir /pendrive
#mount /dev/sdb1 /pendrive
How to unmount & remove an USB Pen Drive/Hard
Disk from Linux System?
#unmount /pendrive
# eject /dev/sdb1
à {Pendrive will stop blinking. Now
remove it}
"The use of COBOL cripples the mind; its teaching should, therefore, be regarded as a criminal offense."
- Dijkstra
vish786 is offline
Old 10-05-2007, 11:06 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: mounting sata drive & pen drive
Is this a tut?
Do this .. [Ubuntu]
sudo apt-get install ntfs-config
Then enable mounting of external with write support via the app .. That's it.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 10-05-2007, 11:15 PM   #3 (permalink)
"The Gentleman"
vish786's Avatar
Post Re: mounting sata drive & pen drive
Originally Posted by QwertyManiac
Is this a tut?
Do this ..
its both a tutorial with a question
wat is sudo???? till now i hav been using mount command for mounting file systems will it work in all the linux OS like mandriva, fedora core, suse, knoppix , mostly famous ones..... and i hav a internal sata hdd not an external
- Dijkstra
vish786 is offline
Old 10-05-2007, 11:25 PM   #4 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
sudo allows you to become the root user temporarily.. And do what Qwerty suggested, easiest way to get ntfs write support..
kalpik is offline
Old 10-05-2007, 11:38 PM   #5 (permalink)
1337 |)00|) \m/
kaustav_geek's Avatar
Sudo actually gives you root privileges but doesn't in fact make you the root.. I guess thats what Sudo is all about nuh ?
My Blog : www.vatsuak.blogspot.com
My DA page : www.burningsilver.deviantart.com
OK..ok..... Ads are bad..
kaustav_geek is offline
Old 10-05-2007, 11:59 PM   #6 (permalink)
"The Gentleman"
vish786's Avatar
so u mean to say tat sata drive will be mounted in writable mode????
- Dijkstra
vish786 is offline
Old 11-05-2007, 10:32 AM   #7 (permalink)
GaurishSharma.com
gary4gar's Avatar
i think he said so
gary4gar is offline
Old 11-05-2007, 02:52 PM   #8 (permalink)
Burning Bright
anantkhaitan's Avatar
Thumbs up Re: mounting sata drive & pen drive
Writable only for root
As far as 'accessing ur media' is concerned best way is to edit ur 'fstab' file:
$ sudo gedit /etc/fstab
Append this as root to ur fstab file:
if media has FAT32 partition :
/dev/<drive> /media/<mount point> vfat users,rw,umask=000 0 0
if NTFS then :
/dev/<drive> /media/<mount point> ntfs ro 0 0
U must be knowing about 'su', but 'sudo' unlike su gives U root privilege only for one execution and U r a normal user again and avoiding possible accidents which u may cause if ur a root
Example :
$ sudo mount /dev/hda2 /media/documents
..::Fedora ::.. Freedom + Infinity + Speech
Registered Linux User #447318
GNUger was here.... Grrr....
Maah! Blog
http://brightedges.blogspot.com/
anantkhaitan is offline
Old 11-05-2007, 03:21 PM   #9 (permalink)
Debian Rocks!
freebird's Avatar
writing in ntfs also possible now.check ntfs-3g
http://www.ntfs-3g.org/
http://linux-ntfs.org/
"The day windows users wake up to reality, it will be doomsday for Microsoft."UNIX like OS are more secure.get urself out 4m M$ http://whylinuxisbetter.net http://tinyurl.com/2amjjc http://fsf.org
freebird is offline
Old 11-05-2007, 07:14 PM   #10 (permalink)
Commander in Chief
It enables for all users ..
Harsh J
www.harshj.com
SATA ROCKS : Fujitsu intros first 2.5" 7200 rpm hard drive with SATA 2.5 interface techtronic Technology News 7 22-03-2009 11:09 PM
Can I attach a new sata drive to my existing Seagate 80GB SATA HDD? praka123 Hardware Q&A 6 04-02-2007 06:28 PM
BEST SATA DRIVE Prajith QnA (read only) 4 08-07-2005 11:44 AM
Problem wth SATA drive. imported_tabrez QnA (read only) 4 12-06-2005 12:58 AM
