Old 10-05-2007, 09:27 PM   #1 (permalink)
The Unknown's Avatar
Default Unable to print. Help!! Urgent!!
I have HP PSC 1400. Drivers are installed. Device is running up. Kernel is latest updated on 8/5/07. Before updation, printing worked. Now not working. Desktop Environment=XFCE4+GNOME
Print cmd accepted but no action.
KDE on ArchLinux
The Unknown is offline
Old 11-05-2007, 12:56 PM   #2 (permalink)
String Phreak
mediator's Avatar
Default Re: Unable to print. Help!! Urgent!!
Remove ur old printer profile and add new one. Then try!
mediator is offline
Old 11-05-2007, 08:54 PM   #3 (permalink)
saurabh.sauron's Avatar
i would recommend downloading and installing HPLIP. it solved my problem, on Fedora Core 6. i think that your printer is supported.
http://hplip.sourceforge.net/
saurabh.sauron is offline
Old 11-05-2007, 09:08 PM   #4 (permalink)
hplip is already installed. it was working b4 i updated my system on 8/5/07.
KDE on ArchLinux
Old 11-05-2007, 09:48 PM   #5 (permalink)
String Phreak
mediator's Avatar
System>administration>printing ....and then add new printer.
mediator is offline
Old 12-05-2007, 10:05 PM   #6 (permalink)
i think that hplip has a a new version, released a few days back. try installing that from source. also, do u have the latest version of CUPS?
Old 14-05-2007, 12:20 PM   #7 (permalink)
Problem solved. Thanx.
I don't which version of CUPS i have. Anyways thanx 4 the info. I may update my HPLIP and CUPS later.
KDE on ArchLinux
Old 15-05-2007, 08:54 AM   #8 (permalink)
FC5 used to print fine with me, but on upgrading to FC6, printing didnt work. upgrading to latest HPLIP drivers, and CUPS worked.
URGENT:Print Screen of output in Turbo C NagpurDaMunda QnA (read only) 6 19-05-2009 11:46 AM
Unable to start TC in Win XP....Its Very Urgent.. Dipen01 Software Q&A 14 09-05-2007 09:35 AM
urgent help how to print .lwp file? shrohit QnA (read only) 2 21-12-2005 06:49 PM
urgent: UNable to play dat files on any player johny_4board Software Q&A 15 28-07-2005 03:12 PM
Unable to print from IE 6 Ricky QnA (read only) 1 21-11-2004 03:39 PM
