| Forum |
#1 (permalink) |
#2 (permalink) |
"The Gentleman"
u can try handy recovery it works on mp3 files and smaller files
"The use of COBOL cripples the mind; its teaching should, therefore, be regarded as a criminal offense." - Dijkstra |
#3 (permalink) |
1337 |)00|) \m/
Try PC File Inspector . It worked for me when I got my partitions deleted during a gentoo installation. However, the chances of you getting those files will depend on the disk usage after the incident.
I used it the very next moment after the deletion without any disk usage.. Hence, I could recover all of my 3 partitions... Best of luck to you for the recovery...
My Blog : www.vatsuak.blogspot.com My DA page : www.burningsilver.deviantart.com OK..ok..... Ads are bad.. |
#6 (permalink) |
Asterisk enthusiast
i don't think any data recovery program will work good in your situation as your partition is over written with ext2 or ext3 file system and now get data back is next to impossiable
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| MANDRIVA LINUX 2007 Instalation PROBLEM | caleb | Open Source | 8 | 29-11-2006 06:22 AM |
| installing vlc player in mandriva linux | Ramakrishnan | Open Source | 2 | 17-07-2006 04:32 PM |
| Partion and Audio problems in Mandriva linux :? | baccilus | Open Source | 78 | 09-04-2006 09:13 PM |
