Old 09-05-2007, 10:37 PM   #1 (permalink)
slash_89
Posts: n/a
Arrow help me install adobe flash player for ubuntu 7.04.
i dwnloaded bith the ".rpm" file "tar.gz" file,
rpm file says some dependencies are missing, tar.gz file says its not compatible with 64 bit version,
i tried installing from firefox directly but it takes me to the dwnload site,
i even tried add/remove programs and package manager but couldnt fine it,
help me out guys.
Old 09-05-2007, 10:46 PM   #2 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Default Re: help me install adobe flash player for ubuntu 7.04.
There is no flash player for 64 bit..
kalpik is offline
Old 10-05-2007, 09:46 AM   #3 (permalink)
slash_89
Posts: n/a
then suppose i want to view videos from UTube, what do i do?
and since i have a amd athlon64 x2 3800+ can i only install 64-bit linux?
Old 10-05-2007, 10:37 AM   #4 (permalink)
Commander in Chief
QwertyManiac's Avatar
Follow this thread .. It installs Firefox 32-bit for 64-bit Ubuntu .. And yes you can alternatively use a 32-bit Ubuntu on your PC too, no issues with it.
http://ubuntuforums.org/showthread.php?t=202537
Harsh J
www.harshj.com
QwertyManiac is offline
Old 10-05-2007, 11:12 AM   #5 (permalink)
kalpik's Avatar
@slash_89: You can install the 32 bit version too! It will work much better, specially for someone who's new to linux
kalpik is offline
Old 10-05-2007, 07:26 PM   #6 (permalink)
slash_89
Posts: n/a
which version of ubuntu feisty fawn is better?
32-bit or 64-bit,
which has more support for apps and packages?
and from where do i get 32bit and how much is it?
eh any help,
and would it be advisible to have 32 or 64 bit ubuntu feisty fawn(keeping even the future in mind),
and currently i have 64bit linux how do i install flash player for it?
Old 10-05-2007, 07:49 PM   #7 (permalink)
kalpik's Avatar
32 bit for all your questions.. Get it from http://www.ubuntu.com its a 700 MB download.
kalpik is offline
Old 10-05-2007, 09:46 PM   #8 (permalink)
slash_89
Posts: n/a
one last query,
hwo come the 32bit version is only 700mb and the 64bit version is 4gb?
and does the 700mb(32bitversion) come preloaded with the same apps or does it miss some things?
i dwnloaded the 64bit torrent which was 4gb.
Old 10-05-2007, 10:42 PM   #9 (permalink)
Kiran.dks's Avatar
64 Bit version is also 700MB.
Kiran Kumar R
Kiran.dks is offline
Old 11-05-2007, 10:46 AM   #10 (permalink)
slash_89
Posts: n/a
>one last query,
Old 11-05-2007, 11:45 AM   #11 (permalink)
kalpik's Avatar
^^ You must have downloaded the DVD.. You just need the CD.. Both 32 bit and 64 bit CDs are 700 MB..
kalpik is offline
Adobe Flash Player 9.0.45.0 rajat22 Software Q&A 3 13-04-2007 02:51 PM
Install Flash on Ubuntu, Linux int86 Open Source 4 12-03-2007 05:25 PM
adobe & flash.. maharajadhiraj Tutorials 1 30-07-2005 08:52 PM
Please help me install adobe reader/real player dhru_banerjee Software Q&A 13 16-10-2004 12:12 AM
- by soumya
- by reddick
