Old 09-05-2007, 06:56 PM   #1 (permalink)
1337 |)00|) \m/
kaustav_geek's Avatar
Exclamation NAT/Firewall Problem
I am using skype and azeurus in SABAYON and I found out that I was firewalled and and hence I was getting very poor speeds and also getting relayed during file transfer in skype.
I'm on Airtel Post-paid connection using Mobile-Office and probably behind an Airtel router. In such a case, how do I bypass the firewall ?
I don't have any firewalls running on my system. Still azeurus displays my system as being firewalled.
I didn't face any such problem in Windows. I'd be glad if anyone could provide a way through this.
My Blog : www.vatsuak.blogspot.com
My DA page : www.burningsilver.deviantart.com
OK..ok..... Ads are bad..
kaustav_geek is offline
Old 10-05-2007, 03:00 AM   #2 (permalink)
El mooooo
eddie's Avatar
Default Re: NAT/Firewall Problem
Just call Airtel and ask them what is their policy regarding closed ports. You are paying good money for a connection and using it to the full is your right. I had a similar problem with Sify and those guys did help in this matter.
eddie is offline
Old 10-05-2007, 07:41 AM   #3 (permalink)
Commander in Chief
QwertyManiac's Avatar
Try installing Firestarter and add a port-rule of opening the port Azureus uses?
Harsh J
www.harshj.com
QwertyManiac is offline
Old 10-05-2007, 07:46 AM   #4 (permalink)
1337 |)00|) \m/
Thanks guys.
@QwertyManiac
What if I'm firewalled from the Airtel Router ? In such a case, firestarter won't help me much.
@eddie
But, I didn't face any such problem in Windows. I used skype without any hassles and was never relayed.
Old 10-05-2007, 08:04 AM   #5 (permalink)
Commander in Chief
I said that only cause you said Windows was going fine, so there's some chance its not Airtel's router that's the cause and just a port issue perhaps.
Harsh J
www.harshj.com
Old 10-05-2007, 03:12 PM   #6 (permalink)
1337 |)00|) \m/
True Indeed. Thanks again.
@QwertyManiac
It worked!! Thanks!!
Last edited by kaustav_geek; 10-05-2007 at 03:12 PM. Reason: Automerged Doublepost
Old 18-05-2007, 11:55 PM   #7 (permalink)
i am also facing same problem. can anybody have any solution. kaustav did you got any solution then do help me out.
amargupta is offline
Old 19-05-2007, 07:26 AM   #8 (permalink)
nach p's Avatar
"UNIX is basically a simple operating system, but you have to be a genius to understand the simplicity."
-Dennis Ritchie
nach p is offline
Old 21-05-2007, 10:26 AM   #9 (permalink)
saurabh.sauron's Avatar
well, try this
install ktorrent. then, activate the upnp plugin. then, forward all the ports that it lists. then, open azureus and close ktorrent. then try to download. this actually works for me as i am also using airtel. in fact, it is better to use ktorrent instead of azureus on airtel, because azureus is not able to forward the ports properly on airtel (at least, that's what i found). i get speeds of 30-35 on my 256 kbps plan.
saurabh.sauron is offline
Problem with Windows firewall bukaida Software Q&A 6 03-08-2006 11:37 AM
Windows firewall problem? rakeshishere Software Q&A 11 05-07-2006 11:53 AM
firewall problem in win xp gvrappu Software Q&A 4 09-10-2005 09:51 PM
Windows Firewall problem.. //siddhartha// Software Q&A 1 05-09-2005 04:08 PM
Firewall problem... shreyas_ubale Software Q&A 9 13-03-2005 05:37 PM
