Old 06-05-2007, 08:44 PM   #1 (permalink)
eagle_y2j's Avatar
Default Amarok engine error
Just updated amarok 1.4.4 to 1.4.5 now i can't play any media it gives
Error:no engine loaded can't start playback
amarokxine and libxine are there on system
Registered LINUX USER #438929
eagle_y2j is offline
Old 06-05-2007, 08:50 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: Amarok engine error
Go to Tools > Configure Amarok > Engine and select Xine there if not already selected.
Plus, its libxine-extracodecs that Amarok needs ..
Harsh J
www.harshj.com
QwertyManiac is offline
Old 06-05-2007, 08:56 PM   #3 (permalink)
eagle_y2j's Avatar
Tools > Configure Amarok > Engine shows no engine (but On yast software management list i can c them installed )
idk but i was able to play media using amarokxine and libxine may be this newer verion needs ibxine-extracodecs
Old 06-05-2007, 08:59 PM   #4 (permalink)
Commander in Chief
No not that way, that extra-codecs allows media like MP3 and a few other popular sorts to play ... Odd the engine isn't showing, can you attempt a re-installation of the Xine engines? Or check if there's an update for them?
Harsh J
www.harshj.com
Old 06-05-2007, 09:08 PM   #5 (permalink)
eagle_y2j's Avatar
Wink Re: Amarok engine error
updated amarokxine now its working fine !
Old 06-05-2007, 09:16 PM   #6 (permalink)
Commander in Chief
Glad it is, Amarok 1.4.5 has album arts now Just enter an album's song list in the explorer and you can see it
Harsh J
www.harshj.com
Old 06-05-2007, 09:40 PM   #7 (permalink)
eagle_y2j's Avatar
^^ lots of new features +changes but splash screen remained same for me !
Old 06-05-2007, 09:42 PM   #8 (permalink)
Commander in Chief
I think that can be customized via the .kde folders. Don't remember exact filenames to give though, maybe eddie will give it if he looks by here ..
Harsh J
www.harshj.com
Old 07-05-2007, 02:32 AM   #9 (permalink)
El mooooo
eddie's Avatar
~/.kde/share/apps/amarok/images/splash_screen.jpg
Here is one I am currently using
@harsh: welcome back man. long time no see
eddie is offline
Old 07-05-2007, 07:00 AM   #10 (permalink)
eagle_y2j's Avatar
On suse 10.2 splash is located here
/opt/kde3/share/apps/amarok/images/splash_screen.jpg
I replaced default with this one
@offtopic: ~ is there any lyrics script for desi songs (punjabi,hindi)
Old 08-05-2007, 12:52 AM   #11 (permalink)
El mooooo
eddie's Avatar
Splash screen in that location will be replaced every time you update Amarok. OTOH any modifications done in your home directory will stay until you make changes yourself.
eddie is offline
Amarok plugins required.. sarincv Open Source 3 24-11-2006 08:51 PM
Installing Amarok in Ubuntu executioner Open Source 1 22-08-2006 04:59 PM
amaroK NTFS Problem ! Zeeshan Quireshi Open Source 6 01-08-2006 08:37 PM
Source Engine vs Doom 3 Engine Sourabh QnA (read only) 4 03-02-2005 04:38 PM
- by soumya
- by reddick
