Old 04-05-2007, 08:06 PM   #1 (permalink)
slash_89
Posts: n/a
Smile Linux installation guidance required.
hi guys,
i just got ubuntu 7.04(feisty fawn),
these are my querise, plz answer all of them,
1. i have alloted 9.3gb for the main EXT2 partition, is it enough?
2. i have alloted 1.5gb for the SWAP partiton, is it enough?
3. is it better to have EXT2 or EXT3 filesystem?
4. ill definately be installing almost of the available linux softwares, so is te above allocated space sufficient?
5. and what is the SWAP filesystem for?
plz answer all the queries in order,
thnx in advance.
Old 04-05-2007, 08:19 PM   #2 (permalink)
Dreamweaver
Gigacore's Avatar
Default Re: Linux installation guidance required.
9.3 GB? the installation itself takes nearly 2 GB so its better u have 15 GB
1.5 GB for swap is enough but consider 2 GB for better performance.
Gigacore is offline
Old 04-05-2007, 08:21 PM   #3 (permalink)
I see right through you.
Sykora's Avatar
To the best of my knowledge,
1) I'd make it larger. I always seem to run out of space for some reason. Try to go for 15GB or so -- more if you can manage.
2) It looks fine. How much RAM do you have? swap should be roughly 1.5 to 2 times your RAM, but generally not more than 2GB.
3) ext3, because it has journalling.
4) See above.
5) swap is similar to virtual memory in windows. It augments your RAM.
I didn't make the world, I only try to live in it.
http://lucentbeing.com
-- Sykora --
Sykora is offline
Old 04-05-2007, 08:30 PM   #4 (permalink)
18 Till I Die............
Again I'd recommend 15-20GB. If you can't give any additional space then resize the 1.5GB swap to ~500MB and give the rest 1GB to ubuntu and I guess you'd be keeping non-system data on a shared partition between linux and windows. How much RAM does your system have?
Also, there are other nice file system around but ext3 is considered best for beginners cos of it's stability and maturity.
http://www.bash.org/?258908
mehulved is offline
Old 04-05-2007, 08:41 PM   #5 (permalink)
Google Bot
Pathik's Avatar
1. 8gb was enuf 4 me..
2. More than enuf
3. Ext3
4. If u r gonna install all packages then u shd keep it 20gb
5.virtual memory.. Similar to swap files in windows..
Pathik is offline
Old 04-05-2007, 09:10 PM   #6 (permalink)
slash_89
Posts: n/a
ok thnx a lot guys,
i have 1gb of RAM, so ill make the swap around 2gb,
and as for the filesystem ill be making it 15gb,
and whats the difference b\w ext2 and ext3?
Old 04-05-2007, 09:17 PM   #7 (permalink)
What are you gonna do with 2GB swap? I have 768MB of RAM and swap usage has never gone beyond 150MB for me. Just make a 300-500MB swap partition unless you're into heavy image editing or multimedia editing and stuff.
mehulved is offline
Old 04-05-2007, 09:22 PM   #8 (permalink)
Dreamweaver
Gigacore's Avatar
how much swap is required for my system @ tech_ur_future ? 1 GB ?
Gigacore is offline
Old 04-05-2007, 09:28 PM   #9 (permalink)
vignesh's Avatar
Nah..not so much.. Just create a swap partition for around 400 megs.. I have 1 gb of ram and the maximum swap usage has been around 60megs...Plus most of the time swap usage is 0.So don`t waste lot space on swap
vignesh is offline
Old 04-05-2007, 09:43 PM   #10 (permalink)
slash_89
Posts: n/a
ok thats cleared,
i have a 40gb hdd only for OS,
NOW i have installed:-
1. XP Pro in drive "C:" and this partition is set active, its size is 19gb,
2. im going to install linux in the remaining space, i.e around 18gb
i have formatted a partiton with EXT3 and its space is 17.5gb and it is a primary partition, i have alloted 1.3gb for linux swap, and this is also a primary partition,
3. so now all 3 partitions are primary partitions, and only the XP pro drive("C:") is set active while the 2 linux partitions are not set active
so after i install linux will i have any booting problems?
Old 05-05-2007, 01:29 AM   #11 (permalink)
Debian Rocks!
freebird's Avatar
Smile Re: Linux installation guidance required.
Linux will run fine from extended logical partns.mostly Windows will be in primary partn and let it.
what is the use of 1.3Gig swap partn!dude only 300-400 MB is enough for even a busy Desktop user.save ur space for some backups than rather using it as swap.just use menu Applications>Accessories>Terminal and enter the command "free" and press enter to see how much swap do u used?most prolly Zero!.tat;s it.300MB is much enough.with u having 1Gigs of RAM.
"The day windows users wake up to reality, it will be doomsday for Microsoft."UNIX like OS are more secure.get urself out 4m M$ http://whylinuxisbetter.net http://tinyurl.com/2amjjc http://fsf.org
freebird is offline
Old 05-05-2007, 11:44 AM   #12 (permalink)
slash_89
Posts: n/a
i am unable to install linux,
i have created a ext3 partiton(17gb) and swap partiton(1gb)
when i select the partiton to which linux should be installed i get a message"no root partition selected"
i used the "/" as the mount point for the ext3 partition and "/swap" for the swap partition,
what else should i do,
plz give the details as to how i partition my disk for ubunt ultimat 1.3 and ubuntu feisty fawn(partitioning details for my above disk configuration).;
Old 05-05-2007, 03:00 PM   #13 (permalink)
It's not /swap it's just swap. swap isn't below /.
I would recommend just create an empty partition non-formatted. And let the installer handle formatting and creating a file system.
Select the other partition as swap
mehulved is offline
Need for Speed Underground 2 - Installation help required! nagarjun_424 Gamerz 16 21-05-2009 10:39 PM
DyneBolic Linux Password Required !!!!! Rishabh_sharma1990 Open Source 3 12-06-2007 07:18 AM
urgent guidance required for UPS abhi_10_20 Hardware Q&A 7 13-03-2007 08:45 PM
- by soumya
- by reddick
