Old 29-04-2007, 06:50 PM   #1 (permalink)
Dreamweaver
Gigacore's Avatar
Smile Whats the difference between Ubuntu & Xubuntu 6.10?
Is Ubuntu better than Xubunt or Xubuntu greater than Ubuntu, what i know is Xubuntu is for low end machines.... is that rite???
Help please!!!
Gigacore is offline
Old 29-04-2007, 07:13 PM   #2 (permalink)
sandeep_arsenal's Avatar
Default Re: Whats the difference between Ubuntu & Xubuntu 6.10?
Ubunut uses Gnome GUI while Kubuntu uses KDE.
Windows users will feel more at home using KDE.
Yes. Xubuntu is for low end machines.
It is recommende tht u use Ubuntu 1st as is the most stable.
Computers have lots of memory but no imagination.
AMD Athlon 64 3000+ , Gigabyte K8N51GMF-9 mobo,
2*256 MB 400 MHz, LG DVD Multi Drive, 128 MB onboard NVidia 6100 GPU
sandeep_arsenal is offline
Old 29-04-2007, 08:40 PM   #3 (permalink)
Custom User Title
Possible's Avatar
Xubuntu uses the XFCE Desktop Envionment, simple easy and light DE that can be customized a lot.
Virgin Aquarian
Possible is offline
Old 29-04-2007, 09:51 PM   #4 (permalink)
C# Be Sharp !
Zeeshan Quireshi's Avatar
XUbuntu Fiesty doesn't seem a lot different from GNOME(differs only in RAM usage )
There are 10 types of people in the world: those who understand binary and those who do not.
Zeeshan Quireshi is offline
Old 30-04-2007, 08:05 AM   #5 (permalink)
Dreamweaver
Gigacore's Avatar
What's the System Requirment to Install Ubuntu 7.04?
Gigacore is offline
Old 30-04-2007, 08:25 AM   #6 (permalink)
18 Till I Die............
You should need 512MB of RAM and I guess something like 800Mhz to 1Ghz processor is the lowest you can go on Ubuntu so it's smooth enough. If you have that I don't think there would be any trouble. If you got less RAM then that go for Xubuntu. If your processor is slower than that, there are other distributions you should be considering IMO.
And yeah the requirements slightly increase with beryl/compiz, you'd need a better processor. I think 512MB RAM should be sufficient though I have seen beryl running on 256MB RAM out of which 8MB was reserved for onboard graphics. It was an Intel 915 chipset board.
http://www.bash.org/?258908
mehulved is offline
Old 30-04-2007, 08:28 AM   #7 (permalink)
Dreamweaver
Gigacore's Avatar
thanks tech.... My System Has:
Intel P4 3.06 Ghz 533 MHz with HT Enabled
256 MB DDR RAM 400 MHz
nVidia GeForce 2 Based Graphic Card with 64 MB Memory (AGP)
Can i run Ubuntu 7.04 or Fedora Core 6 in this Config???
Gigacore is offline
Old 30-04-2007, 08:34 AM   #8 (permalink)
Go for Xubuntu or if you're installing Fedora then install it with XFCE desktop. Don't install GNOME or KDE. I think you should consider adding RAM, if possible. The RAM prices are quite low these days. 1GB DDR1@400Mhz should come for around 3-3.3K so if you can add that much RAM, not only will gnome/kde be smooth but beryl will run nicely too.
mehulved is offline
Old 30-04-2007, 10:57 AM   #9 (permalink)
C# Be Sharp !
currently , DDR2 is about 0.6-1k cheaper than DDR RAM
Old 30-04-2007, 11:01 AM   #10 (permalink)
vignesh's Avatar
I bought a 1gig ram for around 3K.. Now my system is really fast..
You can also try Vector Linux Standard Edition. It comes with XFCE preinstalled.. Its a nice distro if you like Slackware
vignesh is offline
Installing Applications from Kubutu & Xubuntu CDs in Ubuntu vinayasurya Open Source 10 23-06-2006 10:16 PM
DVD's -R/+R.... whats the difference? nevillle23 Hardware Q&A 1 26-12-2005 09:24 PM
Whats the difference between ASP & ASP.NET help_me QnA (read only) 8 08-12-2005 03:31 PM
WHATS THE difference (SRPMS / i386) ???????????????????????? harmax Open Source 1 19-06-2005 07:13 AM
- by soumya
- by reddick
