28-04-2007, 08:23 AM
Dreamweaver
Linux Installation Dilemma!!! Help pls
Awe, all this days i was busy, so couldn't tweak or make some changes to my system, i free now coz of minor fever, so i would like to install Linux to my system. But i would like to have multiboot, so that i shold not miss both windows and linux, i'm not a linux geek, though i'm addicted to its interface.
I dont want to use Live CD,, So a good linux with some glassy interface is what i want.
Please help me which linux to install and how to install without disturbing my current Windows Installation.
I have 80 GB HDD with 7 Partions:
C: 6 GB (system)
D: 14.8 GB
E: 7.81 GB
F: 9.76 GB
G: 9.76 GB
H: 9.76 GB
I: 15.90 GB
I would like to install it H: coz i'm having unwanted stuff.
So do i want to Format H: to RAW and install Linux to it???
And please recommend me a linux which Digit supplies with its CD/DVD..
Help.....
28-04-2007, 10:04 AM
Re: Linux Installation Dilemma!!! Help pls
Install Ubuntu , or openSUSE
28-04-2007, 10:07 AM
Dreamweaver
tank u @ k750i, do i need to format my H: ?
28-04-2007, 11:03 AM
Wire muncher!
yeah obviously u should. but u can do that from widin linux installation. just change the partition type and format. btw, u'll need 2 more partitions for boot and swap. and h: is not the last partition. i'd suggest that u move the data from ur H: and i: to other drives temporarily and resize those 2 partitions to create 1 partition for ur stuff and 3 partitions for linux (the last sectors for boot / and swap).
28-04-2007, 11:09 AM
Dreamweaver
thanks a lot @ infra, so will it not affect my current installation? I couldn't understand what Swap is.... So after installation can i access the boot menu?
28-04-2007, 03:39 PM
GaurishSharma.com
better dissuus all your linux related queries in open sorce section u will get a better response there
28-04-2007, 03:45 PM
Google Bot
you need jus 2 partitions... one for linux and another for swap... install grub in the MBR only... and better go for ubuntu 7.04
28-04-2007, 03:51 PM
Dreamweaver
thanks patix, dear moderator, can u please move this thread to OpenSource???? please
Oh, its already moved, thanks buddy!!!
Reason: Automerged Doublepost
28-04-2007, 04:25 PM
Wire muncher!
swap in linux is different from windows (analogous to the page file). in linux it is usually recommended that you haf a separate partition for swap.
28-04-2007, 05:30 PM
Debian Rocks!
u can see how much swap is used using cmd "free" in a terminal
no need for sperate /boot for newbie desktop install.but a swap partition(select installer for making a swap) of around 300MB is needed,
"The day windows users wake up to reality, it will be doomsday for Microsoft."UNIX like OS are more secure.get urself out 4m M$ http://whylinuxisbetter.net http://tinyurl.com/2amjjc http://fsf.org
28-04-2007, 06:54 PM
Google Bot
AFAIK u need to hav a minimum swap of ur ram size... aint it freebird??
28-04-2007, 06:55 PM
left this forum longback
^^ not necessarily.in my experiance around 300MB is enough for desktop users.
28-04-2007, 07:06 PM
Dreamweaver
How much space does it requires to install Ubuntu 7.04 Completely (Typical Options)
28-04-2007, 07:56 PM
Custom User Title
Intel_Gigacore - Around 2.5 to 3 GB
Virgin Aquarian
28-04-2007, 08:36 PM
Dreamweaver
Thank u possible!!!
Ok Guys finally i have got 6 CDs burnt with Fedora Core 6
Disk 1
Disk 2
Disk 3
Disk 4
Disk 5
Rescue Disk.
Now tell me how to install this to my system without daming the current XP installation in my C:
Link containing this tutor would be great!!!
29-04-2007, 09:01 PM
The Thread Killer >:)
Delete your H: partition from Windows(as this is the easiest method) Then, pop in your Disc 1. You will get a easy GUI which will guide you. Its as easy as clicking Next in Windows. Usually FC chooses the right amount of swap and partition until you specify it manually. Choose your packages before hand and change CDs when it asks. That's it!!
Want to make this world a better place? Then, start seeding and don't be just a leecher :)
30-04-2007, 08:07 AM
Dreamweaver
tank u @ phreak0utt !!!
30-04-2007, 08:41 AM
^ and did u completed the install
30-04-2007, 10:15 AM
#19 (permalink)
Wire muncher!
and i've run fedora 6 for months widout a swap!!!
30-04-2007, 10:22 AM
#20 (permalink)
^^ But even Live cd's search for hdd swap!
30-04-2007, 10:30 AM
#21 (permalink)
Wire muncher!
i never used any swap, and most of the time 1/4th of the ram used to be free, but then again never used any prog which used to hog the memory. just casual surfing, multimedia and programming.... swap is essential NOT mandatory!!! many installations recommend that u set up a swap partition but move on wid the installation even if u dont! at least fedora does.....
try doing it man... jus disable ur swap for sometime (format it as ext2/3/fat whatever other than swap) and try to work on it. unless u use some real resource hogger, ur system will run absolutely fine widout a swap! try it....
30-04-2007, 10:58 AM
#22 (permalink)
Yes they do..
Infra_red_dude , you can aslo create a swap file and add it to the fstab..
30-04-2007, 11:06 AM
#23 (permalink)
18 Till I Die............
but this fellow just has 256mb of RAM so it'd be better he create a swap.
vignesh if I remember right he was the one who put up a thread here on how to create a swap file in linux.
http://www.bash.org/?258908
30-04-2007, 04:57 PM
#24 (permalink)
Wire muncher!
exactly, i sometimes used to share windows swap file (on a fat32 partition) but never actually felt the need anyways....
30-04-2007, 05:05 PM
#25 (permalink)
Dreamweaver
Can i Install Ubuntu KDE by creating swap? Will it run with my current RAM after creating swap?
30-04-2007, 10:09 PM
#26 (permalink)
KDE should run but it will also be a bit slower, you should be able to get it to work faster with some tweaks. eddie should be able to help you there. But realistically KDE would be a bit slow unless you just do some basic work like text editing and web browsing and stuff.
01-05-2007, 08:05 AM
#27 (permalink)
My Ubuntu feisty by default uses by swap partn 80-90MB's.that's why.Always create a swap partition @tleast 300MBs.
