I have this strange problem. first I'll give the facts then the problem.
my college wifi network assign ip address using DHCP.
DHCP assigned ips are in rage of 192.168.0.0 to 192.168.1.0
proxy server is 192.168.1.2
for some weird reason DHCP assigned IP addresses are blocked for net. only ips in rage of 192.168.15.0 works for internet. so i set ip address manually.
now here is the problem. for obvious reason DHCP assigned ip address won't work, so i assign ip address manually for wireless card eth1. Say if i assign ip address to 192.168.15.244 and ping 192.168.1.2 i'm getting error msg "Network Unreachable". but other computers in ip ranges 192.168.15.0 are responding to ping. now if I assign ip address to 192.168.1.244 then it pings successfully to the proxy server. but internet does not work in 192.168.1.0 ip ranges as they are blocked. same configuration in WIndows XP i.e., 192.168.15.244 can ping successfully the proxy server and can browse internet. even my friend is also having the same problem with ubuntu 7.04. can someone solve this weird problem?
