Old 25-04-2007, 05:10 AM   #1 (permalink)
Default booting probblem :Error->device not found
hi i am using opensuse10.2, when booting some "FATAL
error on fan" is occuring i have no idea what is
happenin.. /dev/hda8 is not found and /dev/hda7 not
found and there is error message "There are are no jobs
in this shell" it exits the /sh.... and a prompt gets
printed thats it.. what is happenin... can anyone help
me out..
The actual booting sequences are
usual booting sequences
hdc:ST380011A,ATA Disk Drive
ide at 0x170-0x177,0x376 on irq15
hdc:maax requestsize:512kib
scsi0:ata-piix
ATA:abnormal status 0x7f on port 0xeco
scsi0:ata-piix
ATA:abnormal status 0x7f on port 0xe40
loading fan
loading EDD
BIOS EDD facility v0.16 2004-jan-25,1 devices found
loading jbd
loading mbcache
loading ext3
resume device /dev/hda6 not found(ignored)
waiting for device /dev/hda8 to
appear......................................not found --
exiting to /bin/sh
sh:no job control in this shell
The below is the exact booting sequence when booted in
failsafe mode..
loading EDD
"FATAL : Error inserting
fan(/lib/modules/2.6.18.2-34-default/kernel/drivers/acpi
/fan.ko):no such device"
can you help meh!
-madhan
madhangc is offline
Old 25-04-2007, 07:08 AM   #2 (permalink)
1337 |)00|) \m/
kaustav_geek's Avatar
Default Re: booting probblem :Error->device not found
Umm.. When did the problem start? Was it there right after installation too?? If you made any changes in your hardwae/software.. mention them here.
My Blog : www.vatsuak.blogspot.com
My DA page : www.burningsilver.deviantart.com
OK..ok..... Ads are bad.. ;)
kaustav_geek is offline
Old 25-04-2007, 09:32 PM   #3 (permalink)
vignesh's Avatar
I think this happened while opensuse was booting.. When did this start happening ? What did you do ?
vignesh is offline
Old 25-04-2007, 10:33 PM   #4 (permalink)
yep.. i removed the hdd and took it to my frens home to get some data as.. thats it.. i have done it b'fore and i havent got any problems like this.. i used only the windows partition to transfer data.. wish you can derive a solution..
thanx in advance....
-madhan
guys thanx for your guidance and patience.. i cleared my self the problem.. the problem is that , i installed opensuse as primary master and when i connected as secondry master i had the problem "device not found"..
-madhan
madhangc is offline
Old 26-04-2007, 01:29 PM   #5 (permalink)
vignesh's Avatar
Ah... good.. Just when I was about to ask you to post your fstab and menu.lst.. anyway happy linuxing !
vignesh is offline
Windows XP Booting and Installation Error (LILO Error) arijitraja Software Q&A 3 26-02-2006 03:32 PM
While initializing device NDIS: Windows protection error thind Software Q&A 1 27-01-2005 10:45 PM
Device Driver not found : TPCD001 AMITAGARWAL02 QnA (read only) 5 16-01-2005 04:31 AM
- by soumya
- by reddick
