Old 20-04-2007, 01:28 PM   #1 (permalink)
Default Please Help to Configure USB Based ADSL Modem in RHLE4
Hi, I have a USB Based ADSL Modem which works fine with Win-XP, It is detected and is available in Hardware List in my Red Hat Linux Enerprise 4, I have installed the required driver for it in Linux, BUT the "ttyACM0,1,2.." files are not found and also "ttyUSB0,1,2.." files are absent in /dev and /etc, which are required to configure the Modem, What is Solution?
mavv is offline
Old 20-04-2007, 02:34 PM   #2 (permalink)
Debian Rocks!
freebird's Avatar
Default Re: Please Help to Configure USB Based ADSL Modem in RHLE4
the best bet is to use a pppoe(lan card) connxn for adsl as it is stable.but if u r saying that modem is detected in RHEL,u can try system-config-network-gui or --tui to configure.if device files are not present seems to do with the detection of modem and udev.sometimes modem device files may be even like ttyS0 etc;though u can make dev nodes using "mknod" cmd.also post ur lspci -v .
http://www.cpqlinux.com/dev.html
"The day windows users wake up to reality, it will be doomsday for Microsoft."UNIX like OS are more secure.get urself out 4m M$ http://whylinuxisbetter.net http://tinyurl.com/2amjjc http://fsf.org
freebird is offline
Old 23-04-2007, 09:33 PM   #3 (permalink)
vignesh's Avatar
Try loading the modules
$modprobe usbcore
$modprobe usb-net or usbnet (Either one is right.. I`m not sure )
then run netconfig and enter the ip address , gateway , dns etc.. and do
$service network restart
vignesh is offline
Which ADSL Modem? jack// ani Networking 13 24-07-2008 09:37 PM
Dial up Through Adsl modem vava Networking 6 10-12-2006 06:38 PM
ADSL modem woes phreak0ut Hardware Q&A 9 05-08-2006 03:45 PM
adsl modem for bsnl s2k_ngage Broadband and DTH 8 03-10-2005 12:32 PM
- by soumya
- by reddick
