Old 07-04-2007, 06:22 PM   #1 (permalink)
Vista or Pista(He hee)
Default Guide me.
Hi guys,Kernel update in FC6 or F7 install same.i mean all packeges update with new kernel compile is its same of install F7.
RajuTiwari is offline
Old 08-04-2007, 12:08 AM   #2 (permalink)
El mooooo
eddie's Avatar
Default Re: Guide me.
You'll have to direct your repositories to FC7 ones and then try upgrading from there. I don't know whether it is supported by Fedora but keeping in view the complex nature of RPM distros, I highly doubt that it will work very well. You'll most probably be left with some unacceptable problems after the upgrade so a fresh install is recommended.
eddie is offline
Tv Guide XtremeFuturistic QnA (read only) 13 23-08-2008 10:09 PM
SE user guide or useless guide, wat u say. Destruction Mobiles and Tablets 8 21-03-2007 09:41 AM
Guide to BCA and MCA. DeSmOnD dAvId QnA (read only) 1 24-03-2006 03:49 PM
AMD guide sagargv CPU / Motherboards 1 03-01-2006 09:56 AM
plz guide me drsood123 QnA (read only) 3 15-08-2005 11:04 PM
- by soumya
- by reddick
