Old 07-04-2007, 07:29 AM   #1 (permalink)
Default How to mount pen drive in linux
i want to mount pen drive. i have suse in my comp .
please suggest.
tehnogeek is offline
Old 07-04-2007, 07:42 AM   #2 (permalink)
left this forum longback
praka123's Avatar
Smile Re: How to mount pen drive in linux
if u have gnome desktop,most prolly if u insert pendrive,an icon will pop up in ur Desktop with most latest 2.6 kernel distros.otherwise if it is not mounted,use 'mount /dev/sd** /mnt' ,where ur usbdrive is mostly something like /dev/sdb1 if u have only 1 drive etc
praka123 is offline
Old 07-04-2007, 09:32 AM   #3 (permalink)
18 Till I Die............
Default Re: How to mount pen drive in linux
It does auto mount in KDE too. Technogeek which version of suse have you got?
http://www.bash.org/?258908
mehulved is offline
Old 07-04-2007, 05:54 PM   #4 (permalink)
Console Junkie
aditya.shevade's Avatar
^^ What is the filesystem on the pendrive?
--- Console Junkie
aditya.shevade is offline
Old 08-04-2007, 12:05 AM   #5 (permalink)
El mooooo
eddie's Avatar
Also make sure that your user is part of plugdev and usb groups.
eddie is offline
Old 08-04-2007, 09:46 AM   #6 (permalink)
The Thread Killer >:)
phreak0ut's Avatar
@aditya-Filesystem on pen drives are usually vfat. That's what I read. Please correct me if I'm wrong.
Want to make this world a better place? Then, start seeding and don't be just a leecher :)
phreak0ut is offline
Old 08-04-2007, 10:35 AM   #7 (permalink)
Console Junkie
^^ Ya.... But, (I mean, I have not tried it yet, but) if you format it...... can you change the file system? Say, to ntfs, in case of Win XP? (As I said I have not tried it yet... just a theory).
--- Console Junkie
Old 08-04-2007, 10:13 PM   #8 (permalink)
phreak0ut's Avatar
I haven't tried it myself either, but its highly not recommended.
64 bit linux does not mount. blackleopard92 Open Source 3 20-11-2006 12:17 AM
PC-LINUX OS on USB drive chintan_a Open Source 5 07-08-2006 07:57 AM
SATA Drive support for Linux....! panshul007 Open Source 1 25-04-2005 08:58 PM
Unable to mount all ntfs drives in fedora3.mount one ntfs, neerajvohra Open Source 1 06-02-2005 03:56 PM
Installing Linux in SATA Drive... khandu Open Source 3 09-08-2004 07:18 PM
- by soumya
- by reddick
