Old 05-04-2007, 08:47 PM   #1 (permalink)
cranky's Avatar
Default Partition problem!!
Hi, im using fedora core 6, I also have windows XP on my hard disk (40 GB) and have kept 8-9 GB for linux. Now :
>my root partition is an ext3, with 4.9 GB, out of which im left with just 160 MB free
(I thought 4.9 GB was enough, and i haven't just blindly installed everything on my DVD)
>but my /home partition which is ext3 as well is 3 GB with 2.1 GB free.
>and 512 MB swap, I have a 256 MB RAM
Can i re-partition so that 1GB from /home is allocated to / without formatting either of the partiton, if so how?
Before that, will my system respond any faster if i free up space in root partiton?
I could have just installed fedora without sperate partiton for /home, but thought it would help if i wanted to change the distro..... without formatting the whole thing.
Registered Linux user #426157 (http://counter.li.org/)
cranky is offline
Old 05-04-2007, 11:40 PM   #2 (permalink)
String Phreak
mediator's Avatar
Default Re: Partition problem!!
I dont rely on resizing of partitions, as in many cases I have seen a data loss! Also if ur installing fedora then I advise to have atleast 15 GB for it. So I can only suggest to reformat and reinstall it. I hope u have windows installed in the first partition!
40 gb hdd is too less IMO, for that I think u shud install Ubuntu! Though u can choose the softwares in fedora installation too one by one. But that wud take some 15 minutes I guess!
mediator is offline
Old 06-04-2007, 09:03 AM   #3 (permalink)
cranky's Avatar
then i guess i will remove some more applications that i don't need in order to free up space
cranky is offline
Old 06-04-2007, 09:36 PM   #4 (permalink)
vignesh's Avatar
Try removing some apps thats ur only way out.. Its actually the /usr that requires space since thats where all the software is installed..Its like the Program Files folder in Windows.. Plan better and install next time..
vignesh is offline
partition problem on hp laptop anonymusneo Software Q&A 5 22-03-2007 09:18 PM
partition Magic problem ravimevcha QnA (read only) 3 14-06-2006 12:11 AM
partition problem dhakkan QnA (read only) 2 05-09-2005 07:23 AM
PARTITION MAGIC PROBLEM slugger QnA (read only) 7 26-08-2005 08:24 PM
partition magic problem Techmastro QnA (read only) 4 11-04-2005 07:44 AM
- by soumya
- by reddick
