Old 30-03-2007, 01:51 AM   #1 (permalink)
UbuntuUser
cynosure's Avatar
Default Problem with CD burning
I use ubuntu 6.06
I tried to burn a Cd using gnomebaker (only 400 MBs), but when I tried to rewrite it, I am not able to get this thing to work.
So I wanna ask, does gnomebaker support afterburn?
If not, then is there any other program in linux which can do the same.
Thanks
cynosure is offline
Old 30-03-2007, 02:20 AM   #2 (permalink)
MMO Addict
amitava82's Avatar
Default Re: Problem with CD burning
you mean multi-sessions? i use k3b for CD burning. it supports multi-sessions. install it from package manager.
Steam Profile || Personal Page
Warp drive active. Approaching stargate.
amitava82 is offline
Old 30-03-2007, 11:49 AM   #3 (permalink)
UbuntuUser
cynosure's Avatar
k3b in gnome. Isnt it gonna be a bit slow? Well I'll try and let you know.
Thanks
PS: Yes it was multisession. Windows scrwed up my whole vocabulary.
@amitava82
I tried, but I couldnt find the option. Is this feature activated by default or we need to activate it.
Please tell me how to go about it.
Thanks
cynosure is offline
Old 30-03-2007, 12:34 PM   #4 (permalink)
dissel's Avatar
Originally Posted by cynosure
@amitava82
Thanks
When you press burn it is under settings tab
dissel is offline
Problem with CD burning Shikhar QnA (read only) 7 19-05-2007 06:58 PM
Problem Regarding Dvd Burning N Roy Software Q&A 1 01-01-2007 10:15 AM
problem in cd burning bkmishra1000 Software Q&A 3 13-05-2006 08:10 PM
DVD - Burning Problem!!! Aanand QnA (read only) 2 19-09-2005 10:59 PM
Problem with Burning navneeth_snr QnA (read only) 13 12-10-2004 01:33 PM
- by soumya
- by reddick
