Old 28-03-2007, 02:48 PM   #1 (permalink)
Console Junkie
aditya.shevade's Avatar
Unhappy OpenSuSE updater applet problem
Hi
The applet starts fine, searches for updates fine, but when I click on install, then it asks for root password, and on clicking on continue after entering the password, nothing happens.
I waited for about 10 minutes on 2 occasions, but nothing happens after entering the root password. What may be the problem? Should I reinstall it? How?
Aditya
--- Console Junkie
aditya.shevade is offline
Old 01-04-2007, 12:37 PM   #2 (permalink)
The Thread Killer >:)
phreak0ut's Avatar
Default Re: OpenSuSE updater applet problem
You got the right repos? You can try this site for extra repos. You really get a LOT of updates. http://linux.wordpress.com/2006/12/1...ries-for-yast/
Thanks to Mehul for the site
Want to make this world a better place? Then, start seeding and don't be just a leecher :)
phreak0ut is offline
Old 01-04-2007, 06:20 PM   #3 (permalink)
Console Junkie
^^ It can find updates. I can see a long list. But whenever I click install and then.. read the first post. Repos are correct.
--- Console Junkie
Old 01-04-2007, 10:50 PM   #4 (permalink)
phreak0ut's Avatar
Try removing the repos and add it again. If it can probe for it, it should work fine. If this doesn't help, try reinstalling the zen-updater. Dunno, if it is safe, but worth a try I guess
TRY IT YOUR RISK
Old 01-04-2007, 11:11 PM   #5 (permalink)
Console Junkie
^^ Ah.. zen updater sucks. Kalpik asked me to use this applet, cause zen has been having problem since the first time I installed SuSE.
About the removal of rpms, I will give it a try, but still, t's kinda like the last resort....
Aditya
--- Console Junkie
Old 02-04-2007, 12:02 AM   #6 (permalink)
TheSaint
NucleusKore's Avatar
I've thrown zen updater out alltogether in my Open SuSE 10.1. I use software management in YaST. Its a LOT more easier
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 02-04-2007, 05:06 PM   #7 (permalink)
phreak0ut's Avatar
^^But isn't it easier to have constant updates at your hand rather going through it in YaST?
Old 02-04-2007, 05:11 PM   #8 (permalink)
Console Junkie
^^ Exactly.
--- Console Junkie
Old 03-04-2007, 10:00 AM   #9 (permalink)
phreak0ut's Avatar
Try uninstalling the applet and reinstalling it. Something wrong with applets on this distro I guess. My gnome-applets were corrupt, dunno the reason. The reinstall should do the trick.
OpenSuSE 10.2 and avi files problem... aditya.shevade Open Source 13 28-03-2007 02:08 PM
has anyone used nokia software updater arunks Mobiles and Tablets 12 24-12-2006 02:23 AM
Nokia Software Updater neerajvohra Technology News 16 31-08-2006 02:26 PM
Yahoo games java applet error geekhead83 Gamerz 1 08-09-2005 05:24 PM
- by soumya
- by reddick
