Old 27-03-2007, 06:27 PM   #1 (permalink)
The Thread Killer >:)
phreak0ut's Avatar
Default Messed up monitor settings and no X
Hi!
I was checking out the post of installing beryl on my system. Well, according to the post on wiki, they had just mentioned that 3D acceleration should be ticked. But, I just went to the monitor section and saw that the wrong monitor company was selected, i.e., Sampon or something. I chose Samsung and since my model 55V wasn't available, I selected 55B. Dunno why I did it but now, I cannot start X. The monitor goes blank and the green light starts blinking. How can I reset the settings to normal?
__________________________________________________ ________________________________
EDIT: Hey, wait a sec. I remember backing up my xorg.conf. How can I replace it?
I'm almost getting there (Grrrr...... opera is crashing on windows when I select quick reply )
Want to make this world a better place? Then, start seeding and don't be just a leecher :)
phreak0ut is offline
Old 27-03-2007, 06:30 PM   #2 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Default Re: Messed up monitor settings and no X
You can issue sudo cp /etc/X11/xorg.conf.backup /etc/X11/xorg.conf
Where xorg.conf.backup is the name of the backup xorg.conf..
kalpik is offline
Old 27-03-2007, 06:34 PM   #3 (permalink)
phreak0ut's Avatar
The backup file name is this: /etc/X11/xorg.conf.$(date +%y%m%d-%H%M%S)
Old 27-03-2007, 06:46 PM   #4 (permalink)
desertwind's Avatar
Simple command will do.
sudo cp /path/to/backup/file /etc/X11/xorg.conf
After this restart X.
Sometime you'll think you understand everything
...Then you'll regain consciousness
desertwind is offline
Old 27-03-2007, 06:54 PM   #5 (permalink)
phreak0ut's Avatar
I am such a moron! I backed up the file AFTER I had made the changes to SaX2 So, still stuck with the screwed up one.
EDIT: trying to backup from xorg.conf~ gives me an error like "cannot stat /etc/................."
Old 27-03-2007, 08:04 PM   #6 (permalink)
18 Till I Die............
Just run xorgconfig again. It should more or less detect everything alright.
http://www.bash.org/?258908
mehulved is offline
Old 27-03-2007, 10:06 PM   #7 (permalink)
phreak0ut's Avatar
Red face Re: Messed up monitor settings and no X
Well, I could have, but I just reinstalled my system. Learnt my lesson the hard way.
Old 27-03-2007, 10:14 PM   #8 (permalink)
and the wrong way.
mehulved is offline
Old 28-03-2007, 10:15 PM   #9 (permalink)
phreak0ut's Avatar
True
OK, I've reinstalled the distro. Updated the machine from the repos from here Even updated compiz, beryl and all the works. Now, I've got a different problem. I want to enable compiz and desktop effects, but I get an error message 'x11-video-fglrx' is not available for installation and it asks for Software Update, but when I click OK, it shows that the file is not available for download But, I installed this and one more driver according to this site. But, I still can't enable the Desktop effects and I keep the same error message over and over again. What do I do?
Fixed the problem myself. Reinstalled the ATI driver, but this time with the proper distro chosen. This is the third time which I installed the driver. Whew!!
Monitor settings gofeddy Hardware Q&A 1 14-03-2007 11:50 AM
samtron monitor settings sujay_36 Hardware Q&A 1 19-06-2006 11:21 PM
Monitor power settings not workin' properly crashuniverse QnA (read only) 8 11-09-2005 02:16 PM
msi messed it up ASH18MARCH QnA (read only) 3 24-07-2005 11:49 AM
Messed up while partitioning!Pls help. harpoon QnA (read only) 4 05-09-2004 07:14 PM
- by soumya
- by reddick
