Hello
Have some good and bad news.
Good is tat i can finally boot the DVD
I made the DVDRW drive as primary slave and am able to boot the DVD.
Now the bad news. Im still not able to install
The problem is after the progress bar reaches almost completion(when i select livecd, gui installl, console install etc), the monitor goes blank and monitor led blinks. So it implies my monitor is not detected. When i press Ctrl+Alt+F1 , i get the console. When i try to start gdm(/usr/bin) or Xsession(/etc/X11), I get the foll error messages :
xterm xterror : cant open display %s
xterm : Display not setup
I also tried copying xorg.conf.legacy to xorg.conf and also tried configuring xorg.conf again. But no use.
I can get to console. Can i install from there, is there ne provision???
My monitor is Proview PA-456.
Cheers
