Old 15-03-2007, 11:08 AM   #1 (permalink)
titun
Posts: n/a
Default Running firefox without installing, is it ok ?
In Fedora Core 5 , firefox provided is version 1.5. So I removed it using rpm -e firefox.
Then downloaded the latest 2.0.0.2 version in tar.gz format. Extracted it to a folder. Now I can directly run it by double clicking the firefox script in the folder.
I see all the files related to firefox are in that extracted folder and in .mozilla folder of my home dir.
So I don't need to install it as the usual RPM way ??
Can someone explain why this tar.gz runs directly withour installing. This method seems easy to use a software, so why do we use .rpms ?
Old 15-03-2007, 11:37 AM   #2 (permalink)
desertwind's Avatar
Default Re: Running firefox without installing, is it ok ?
the firefox tarball needs no installing. You can use it straight away.
remember to create a symlink of executable to /usr/bin folder so that other apps can access firefox as well.
This way is not recommended because it make tracking of packages much difficult.
Sometime you'll think you understand everything
...Then you'll regain consciousness
desertwind is offline
Old 15-03-2007, 11:47 AM   #3 (permalink)
titun
Posts: n/a
Thanks. I see this /usr/bin is where all the software links are. Humm...slowly this tux bug is bitting me.
I will have to search the command to make a symbolic link.
Btw there are all the tared softwares behave the same way ?? None requires installation ?
Old 15-03-2007, 02:10 PM   #4 (permalink)
desertwind's Avatar
Nope. Usually tarballs will be source files, not precompiled binaries.
for firefox you follow this
first untar the file.
tar -xvzf firefox-2.*.tar.gz
cd into the directory
cd firefox
make a symlink
ln -s firefox /usr/bin/
Old 15-03-2007, 09:53 PM   #5 (permalink)
18 Till I Die............
There should be surely be a repository available for Firefox2 for FC5 too.
http://www.bash.org/?258908
mehulved is offline
