Hmm strange, i feel it should boot into CLI mode as said by tech_your_future, i think u may have missed a space, i mean before typing 1, give a space.
--->Another approach: I had similar problem in ubuntu. When it shows "sync out of range" message, press <ctrl><alt> - OR <ctrl><alt> +
either of these two combination usually reduces your screen resolution and you can altleast see something.... try pressing the above keys two or 3 times if it doesn't work.
If still doesn't work
then somebody in this forum will help u out...
If it works
, then edit the /etc/X11/xorg.conf file (im sure you will find that file this time) as follows:-
>Your file will be similar to as shown by spynic in prev post. The main problem i feel is the resolution, find this part in the file:-
Modes "1024x768" "800x600" "640x480"
for a 17" monitor, erase all the resoultions greater than 1024x768, don't erase the lower resolution u may need that.
>Now you should check horizontal & vertical refrsh rate, if u don't know what to set & u don't have a manual, then login to windows, press some of the buttons on ur monitor, it may show something like H:68.5K and V:84 (I don't know how it shows for samsung) OR u can try the values i've mentioned, even i have a 17" inch CRT (non-flat)
>Save the file BUT keep a copy of the old file before saving, u may need it if u edit it wrong.
>It should work correctly the next time u boot
You could have avoided this problem in 1st step of installation itself (i have installed FC about 3-4 times now
)....instead of just hitting enter to start the installation, if u had typed at the prompt:
>linux 1024x768
and then enter, i think it would have worked fine.... this is for FC.
careful with the editing!!
