Old 14-03-2007, 03:48 PM   #1 (permalink)
cranky's Avatar
Question avi to mpeg converter
Any one knows any good software in linux that converts avi files to mpeg format??
Registered Linux user #426157 (http://counter.li.org/)
cranky is offline
Old 14-03-2007, 04:58 PM   #2 (permalink)
desertwind's Avatar
Default Re: avi to mpeg converter
ffmpeg
mencoder
Sometime you'll think you understand everything
...Then you'll regain consciousness
desertwind is offline
Old 14-03-2007, 05:16 PM   #3 (permalink)
String Phreak
mediator's Avatar
http://ubuntuforums.org/showthread.php?p=2285238
mediator is offline
Old 15-03-2007, 09:00 PM   #4 (permalink)
cranky's Avatar
Thanx for the replies... will check it out
cranky is offline
Old 15-03-2007, 09:46 PM   #5 (permalink)
Be CoOl rAp RuLeZ !!!
krates's Avatar
http://www.freedownloadscenter.com/B...peg-linux.html
Try The Above Link It Will Show You Many Converter Try It Many Of Them Are Freeware
iPhone 3G 16GB + Samsung I450 + Sennheiser CXL 400 + PSP Phat + Samsung NC10 :D
Previous phones: N73ME , W810I , Asus P320
krates is offline
Old 15-03-2007, 10:28 PM   #6 (permalink)
18 Till I Die............
With softwares like ffmpeg and mencoder, I wonder why you need to look at something else. You may try to look for a GUI front end for these if you find CLI too difficult. But, these softwares are really good for media conversion.
I also read of something called transcode. But, haven't used it though.
http://www.bash.org/?258908
mehulved is offline
