Does Ctrl+Alt+Backspace restart X? While testing different settings in some games, if the game crashes, desktop won't regain its native 1024x768 resolution. In such situations, the only method I know is to reboot.
Originally Posted by tech_your_future
never seen that happen.
After installing Kubuntu, I had to change my default sound card from the onboard one to the PCI one. For that I had to edit a file, after which if I knew how to restart sound system, I could have avoided a restart.
If I am not wrong iptables is built into kernel so no way it can fail unless it's a problem with kernel. But, would like to know more on this one.
What I was actually thinking was to enforce a firewall policy change. Now I understand that Guarddog and Firestarter can do it easily.
Originally Posted by freebird
for refreshing the X use xrefresh -white command.
For GNOME,it got a gnome-panel applet "force-quit" just add it to the panel and press it and press the failing gui app for killing the app sudden.
For sound u can restart alsa,use alsactl -d store to save volume control.
Doesn't xkill do the same as force-quit?
Did you mean "alsactl restore" when you typed alsactl -d? I haven't tried any of these yet.
About the keyboard redetection: I have been experiencing a strange problem with my Kubuntu for the past 3 days. While I am typing something, suddenly, the keyboard response becomes too slow. For example, if earlier the key repetition rate was 5 characters per second, now it becomes 1 per 10 second. I experienced this problem only when I am posting something here using Firefox. At first I thought it was because of my Microsoft USB keyboard. So I attached my PS2 keyboard also. But still the problem occurs. Reconnecting to another port won't help either. In the past 3 days, it has happened 7 times. Once it happens, I have to reboot. Everything else including mouse functions normally. So, I was thinking if I could make Kubuntu redetect the keyboard, may be I could avoid a reboot. (I was actually thinking about posting this as a different thread soon, after testing in Mandriva.)
Anyway, thank you guys for replying so soon. Sorry for the delay from my part. I was looking for the remaining methods.
