Old 09-03-2007, 08:41 PM   #1 (permalink)
cranky's Avatar
Angry mplayer installation problem using yum on FC6
I use an FC6, i tried installing mplayer.i386 using the yum install command, after resolving the dependencies and showing a table as to which all packages it wishes to download, i hit the 'y' key to download, then it showed the below error after downloading all those packages:
Transaction Check Error:   file /usr/lib/libavcodec.so.51 conflicts between attempted installs of ffmpeg-libs-0.4.9-0.34.20070204.lvn6 and ffmpeg-0.4.9-0.8.20070109.fc6
  file /usr/lib/libavformat.so.51 conflicts between attempted installs of ffmpeg-libs-0.4.9-0.34.20070204.lvn6 and ffmpeg-0.4.9-0.8.20070109.fc6
  file /usr/lib/libavutil.so.49 conflicts between attempted installs of ffmpeg-libs-0.4.9-0.34.20070204.lvn6 and ffmpeg-0.4.9-0.8.20070109.fc6
Some more info.....
>I had previously installed ffmpeg from sources, then after getting this error i uninstalled it using 'make uninstall' command
>Then, checked if the conflicting files (in '/usr/lib' dir) were deleted, they were.
Even after this, when i try i get this same error, what could be the problem.
Registered Linux user #426157 (http://counter.li.org/)
cranky is offline
Old 09-03-2007, 08:56 PM   #2 (permalink)
Debian Rocks!
freebird's Avatar
Post Re: mplayer installation problem using yum on FC6
ffmpeg compiled installed from source..Ok.but still some files may be header files are there.try reading the original script for the inst directories and files.
in my debian install:
p*edonwinxp:~# whereis ffmpeg
ffmpeg: /usr/bin/ffmpeg /usr/X11R6/bin/ffmpeg /usr/bin/X11/ffmpeg /usr/include/ffmpeg /usr/share/man/man1/ffmpeg.1.gz
just search /usr/include dir for ffmpeg or like file,remove it manually.
next time while installing from source.check this software- Checkinstall-it will make rpms or debs from source.
Checkinstall:
http://asic-linux.com.mx/~izto/checkinstall/
"The day windows users wake up to reality, it will be doomsday for Microsoft."UNIX like OS are more secure.get urself out 4m M$ http://whylinuxisbetter.net http://tinyurl.com/2amjjc http://fsf.org
freebird is offline
Old 09-03-2007, 11:37 PM   #3 (permalink)
18 Till I Die............
Default Re: mplayer installation problem using yum on FC6
And are you mixing different repositories like livina, atrpms and such? That could also be problematic too.
http://www.bash.org/?258908
mehulved is offline
Old 10-03-2007, 12:16 AM   #4 (permalink)
cranky's Avatar
ok now i made sure i removed all that was installed from my previous ffmpeg installation, and mplayer also installed successfully, i had given this command: yum install mplayer.i386
but whenever i start it i end up getting this error:
mplayer: symbol lookup error: /usr/lib/libavcodec.so.51: undefined symbol: faacDecOpen
what should i do?
cranky is offline
