Old 07-03-2007, 12:46 PM   #1 (permalink)
hailgautam's Avatar
Default How to browse CD/DVD
I have set the correct Screen Resolution, Configured Wifi and Mobile Internet. Can read/write from NTFS partitions and also vice versa from XP - read write the ETX3 partitions. Installed Beryl and running it with out crashing it at all . ALL With the help from this forum.
Only problem is now remaining - I am not able to browse any CD/DVD. However, other Linux Distribution CDs/DVDs get mounted automatically and I can browse them. It also recognizes the OpenSuse DVD (PCW) - can't browse it though. My previous attempts were all disasters with my system some problem or other...
My system is a Dell Inspiron 6400, it has a Philips 24x CD-RW/DVD-Rom Combo. I am on OpenSuse 10.2. Can some one give me a step by step tutorial so that I can configure to mount all types of CD/DVDs like the Mp3s and DVDs containing *.avi files and Digit Magazine CD/DVD.
Thanx a lot in Anticipation.....coz i know i will get the solution.
Change is Nature, the part that we can influence; and it starts when we decide.
Where you going?
With Luck forward.
hailgautam is offline
Old 07-03-2007, 12:54 PM   #2 (permalink)
The Unknown's Avatar
Default Re: How to browse CD/DVD
Buddy explain more clearly.
KDE on ArchLinux
The Unknown is offline
Old 07-03-2007, 01:00 PM   #3 (permalink)
hailgautam's Avatar
If I put a CD/DVD nothing happens, I can't see a CD or DVD - it does not get mounted - and therefore can't browse it. Some CDs get mounted and can be browsed like the Ubutntu 6.10 CD, but other CD/DVDs like those of Digit Magazine CD/DVDs are not to be seen anywhere..
Am I clear now or is there anything you want to know?
Where you going?
With Luck forward.
Old 07-03-2007, 01:06 PM   #4 (permalink)
Digit CD\'s are designed for WINDOWS ONLY. IT SEEMS THAT YOU DO NOT READ THE LICENSE AGREEMENT WHICH APPEARS WHEN U INSERT THE CD.
__________
If i does not mount, try mounting it in the terminal. I do not remeber the command since it has been years since i stopped using linux but i am going to start again on 17 th March 07. On that day, i am going to uninstall windows completeley. Wait for some linux guru\'s like Mehul to come.
KDE on ArchLinux
Old 07-03-2007, 01:47 PM   #5 (permalink)
18 Till I Die............
See if this command works
su
mkdir /media/DVD
mount -t auto /dev/hdd /media/DVD
Replace hdd with whatever is the device name of the drive. I feel the problem is that cd/dvd's are scratched hence not readable. Or else HAL should mount it automatically.
http://www.bash.org/?258908
mehulved is offline
Old 07-03-2007, 02:07 PM   #6 (permalink)
hailgautam's Avatar
how do i know the device name?
Where you going?
With Luck forward.
Old 07-03-2007, 02:14 PM   #7 (permalink)
sudo fdisk -l
mehulved is offline
Old 07-03-2007, 07:53 PM   #8 (permalink)
hailgautam's Avatar
It works, but not i an not able to remove the dvd, it says "You are not privileged to eject this volume." Another question is it a permanent solution, that is would i be able to browse any dvd/cd with executing this code or will i have to do it every time...
Where you going?
With Luck forward.
Old 07-03-2007, 10:30 PM   #9 (permalink)
The Devil
blackpearl's Avatar
type
sudo gedit /etc/fstab
Then add these lines in the fstab file
dev/DVDrom	/media/DVD	auto	defaults	0 0
Replace DVDrom with the correct DVD drive device name
I hope I got it right.
blackpearl is offline
Old 07-03-2007, 11:52 PM   #10 (permalink)
hailgautam's Avatar
still i am not able to eject cd/dvd from the drive.
Where you going?
With Luck forward.
Old 08-03-2007, 04:50 AM   #11 (permalink)
left this forum longback
praka123's Avatar
Smile the device file needs to be probed and listed in /etc/fstab
Do post ur /etc/fstab entry.
the block device files for the DVD/CD drive are most prolly something like hdx,where x will be a,b,c etc..
if u have an ide hdd,then ur DVD drive will be /dev/hdb and if ur hdd is SATA,then DVD drive will be /dev/hda.inspect /dev/ directory for such a file and proceed.
You can check using below command:
~# ls -l   /dev/ |grep hd*
first make sure u have a directory as follows;or mkdir One.
~#mkdir  /media/cdrom0
nano is an easy-to-use editor from command line.edit /etc/fstab.append this entry at bottom.
~#nano -w /etc/fstab
/dev/hda        /media/cdrom0   udf,iso9660 user,noauto     0       0
Save the file.
Now it will mount DVDs/CDs automatically.
Regarding local user not able to mount,you can make the group "cdrom",local users supplimentary or secondary group using "usermod -G" command.but as you use Suse,there must be some gui tools for GNOME or kde allowing user to do these things.some distros facilitate that if ur a member of "wheel" can execute all this.
In Linux,CD/DVDs are ejected by right clicking and selecting eject or umount option.
But In My Debian and Ubuntu,Thanks to HAL & co,by pressing the CD/DVD drive eject button also ejects the CD/DVD.suse also may have such an option
praka123 is offline
Old 08-03-2007, 11:13 AM   #12 (permalink)
hailgautam's Avatar
1. The Name of my CDRW/DVDROM combo is
dev/sr0
2. I realized that I did not have any problems with CD ROM Disks, they automatically get mount and I can eject them by pressing the eject button, and also can browse the contents. The problem is with DVDs only.
3. I already have a folder which I created on advise from T_Y_F - and I have to manually mount the DVDs to browse. But he did not tell me how to unmount it , so not able to eject the drive
/media/DVD <====The folder
mount -t auto /dev/sr0 /media/DVD <---------Code to Mount dvds
4. the following is the extract from /etc/fstab
/dev/sda7            /                    ext3       acl,user_xattr        1 1
/dev/sda8            /home                ext3       acl,user_xattr        1 2
/dev/sda2            /windows/C           ntfs-3g       rw,users,gid=users,umask=0002,nls=utf8 0 0
/dev/sda5            /windows/D           ntfs-3g       rw,users,gid=users,umask=0002,nls=utf8 0 0
/dev/sda6            swap                 swap       defaults              0 0
proc                 /proc                proc       defaults              0 0
sysfs                /sys                 sysfs      noauto                0 0
debugfs              /sys/kernel/debug    debugfs    noauto                0 0
usbfs                /proc/bus/usb        usbfs      noauto                0 0
devpts               /dev/pts             devpts     mode=0620,gid=5       0 0
dev/sr0                 /media/DVD              auto         defaults               0 0
The last line i had inserted as advised by blackperl...
So what I do now?
Where you going?
With Luck forward.
Old 08-03-2007, 11:21 AM   #13 (permalink)
Change defaults to ro, user, auto
And to unmount use the command umount, notice the absence of n after u.
mehulved is offline
Old 08-03-2007, 11:23 AM   #14 (permalink)
The Devil
blackpearl's Avatar
Replace the term "default" in the 4th column of the last line (i.e. the DVD line) with:
If its a DVD ROM
ro,auto,user,exec
If its a DVD Writer
rw,auto,user,exec
Also the first term of the last line is "/dev/sr0" not "dev/sr0"
Notice the "/"
Old 08-03-2007, 12:00 PM   #15 (permalink)
Debian Rocks!
freebird's Avatar
nice.you got the soltn
"The day windows users wake up to reality, it will be doomsday for Microsoft."UNIX like OS are more secure.get urself out 4m M$ http://whylinuxisbetter.net http://tinyurl.com/2amjjc http://fsf.org
freebird is offline
Old 08-03-2007, 12:04 PM   #16 (permalink)
hailgautam's Avatar
thanks T_Y_F and Blackpearl, praka123 it is now working all right, seems I am reping you guys a lot, so the system is not allowing me to do it again
Thanks again
Where you going?
With Luck forward.
