Old 04-03-2007, 11:58 PM   #1 (permalink)
cranky's Avatar
Angry Fedora 6 post installation problems
Hi, I installed fedora core 6, now when i start, the screen goes blank and stays like that giving me no choice but reboot. This happens just a few seconds after that "Press I for interactive mode" message appears.
>I have done the media check and it passed
>I have / and /home as two seperate ext2 partitions
>Tried entering rescue mode, thought it was graphics problem, but couldn't edit /etc/X11/xorg.conf file coz it shows no such file or directory (weird )
I'm sure its installed properly.
Mine is Intel 845G, P4 2.4Ghz, 256MB RAM, dual boot with Windoze XP as the other OS
Registered Linux user #426157 (http://counter.li.org/)
cranky is offline
Old 05-03-2007, 07:10 AM   #2 (permalink)
18 Till I Die............
Default Re: Fedora 6 post installation problems
What's the partition size allocated to /
And make one partition for swap or else your computer won't be able to handle with just 256mb of RAM.
Also, it's better to use ext3 for it' journalling support.
http://www.bash.org/?258908
mehulved is offline
Old 05-03-2007, 03:09 PM   #3 (permalink)
cranky's Avatar
I forgot to mention, I have kept 512MB for swap, 7GB for / & 3GB for /home
I have formatted both as ext2.
__________
Well.... I just re-installed it and its workin fine
cranky is offline
Old 05-03-2007, 06:06 PM   #4 (permalink)
Just another linux lover.
subratabera's Avatar
Try this command...
system-config-display
Today is a most unusual day, because we have never lived it before; we will never live it again; it is the only day we have.
(Registered Linux User #432737 - subratabera.blogspot.com)
subratabera is offline
Old 05-03-2007, 06:27 PM   #5 (permalink)
Google Bot
Pathik's Avatar
well a similar thing happened to me... and i found no solution... better try another distro...
Pathik is offline
Old 05-03-2007, 07:11 PM   #6 (permalink)
cranky's Avatar
Well... I just tried re-installing it and now everything is fine
cranky is offline
