| Forum |
#1 (permalink) |
This problem has been troubling me for the past two days. Whenever I do something like installing software, browsing using opera, opening torrents etc., the system kind of stops responding. I can see the hard disk activity led blinking continuosly indicating heavy swap usage. When this happens, I can't do anything but restart. Even the mouse pointer moves very very very slowly. All I can do is <Alt><SysRq><B>. The system responds immediately to that, but not for any other commands. Even <Ctrl><Alt><F1> takes ages to load. If I leave it like that for some time, KDE crashes, but still the activity continues. Is there anyway to determine what's causing this behaviour? What's worse is that yesterday this happened when I was showing off my Linux system to a Windows, but soon to be Linux, user. He came to my home to download something. We spent nearly 2 hours trying to do it via Linux, and finally did it in 5 minutes from Windows |
#2 (permalink) |
Debian Rocks!
You can find what is using the hdd and memory by issueing "top" command
~$top OR ~$htop (if available)
"The day windows users wake up to reality, it will be doomsday for Microsoft."UNIX like OS are more secure.get urself out 4m M$ http://whylinuxisbetter.net http://tinyurl.com/2amjjc http://fsf.org |
#3 (permalink) |
18 Till I Die............
What's the amount of RAM on your system? I personally found Mandriva bloated and way too slow on 256MB of RAM. But, still KDE crashing is not done.
http://www.bash.org/?258908 |
#4 (permalink) | ||
Firefox - 4/6 times Akregator - 3/6 times Opera - 3/6 times KTorrent - 1/6 times Thunderbird - 1/6 times I am mentioning these in the hope that it would give you guys some clue. Another thing I noticed while typing this reply is that when I did 'ps -e' , I saw 4 instances of 'acroread' and 10-12 instances of 'kio_file' and 8 instances of 'kio_http'. The total number of tasks at that time was 115. I didn't open Acrobat Reader. So, I don't know how it started. According to 'top', now it is 85, about 3 MB RAM is free & swap usage is 320 MB. What's the command to determine parent of a process? |
#5 (permalink) |
Debian Rocks!
sure does have some relation with kde apps?
#6 (permalink) |
kiio_file and kio_http are kio_slaves. kio_slaves are required by KDE.
Try installing something like XFCE and use it for a few days and see if the crashes still go on or not?
#7 (permalink) |
Debian Rocks!
i think @eddie can solve ur problem
#8 (permalink) |
left this forum longback
@t_y_f:
that was a tough suggestion-that to install XFCE. ,then I will say install GNOME-2.16@Unni, Perhaps it may help that by checking the logs logged in /var/log/ dir of your distro.may be kde too logs out its state.just check. the normal commands you may be knowing- dmesg or "less /var/log/syslog" etc..hope it helps... ..and did u noticed the same hdd load while logged in as root or any other user?
left this forum long back.Admin Can Delete this Account and posts Permanantly.Thank You Get GNU/Linux - http://getgnulinux.org |
#9 (permalink) |
Try me
Whenever inmy life i tried using OSS .. mostly FC series i was always confused what to do in it...
and mind you errors are also mind blowing man about three months back i installed FC5 in my pops comp. and it was running damn slow.. but the config was to high .. i dont know why...But surely its somewhat complicated ...
Forum rules: http://www.thinkdigit.com/forum/announcement.php?f=3 Blog at : http://thecomputernext.com/blog |
#10 (permalink) |
@shantanu_webmaster:
that is a very biased answer.Fedora can be made faster,just stop the services it starts by default,sometimes fedora even starts NFS,Sendmail etc though it was not configured.I do understand that reluctance or a negative attitude definitely not going to help anyone.I hope You too
#11 (permalink) |
Try me
yeah i agree to you ,
but sometime back . i myself was trying FC6 64bit edition.. i wanted to have a deep look to it , this time on my PC it worked just fine with Xp and vista in triple boot.. i managed myself to make resolv.conf and wvdial and all these files to DIAL-up to internet with my serial modem.. setting it up my way.. even for running MP3 it took me 10 hard days and for installing Nvidia drivers i am trying YET but i aint saying LINUX is BAD --its just complicated.. and a windows user (means a long time windows user) might have probs in it.. Even i think after desktop opens .. that now what should i do... the only reason for me to install linux was Python and i just praised you OSS guys for your management with linux
#12 (permalink) |
Linux is more simpler for us since we've spent more time on linux than windows. You'll are used to windows ways of doing things so linux's ways seem difficult. Installing 64 bit linux is a bit of a problem for now as 64 bit computing is in a nascent stage. For installing nvidia drivers you need to enable extra repositories. I don't use FC so don't know it as such, but google will help here. I am using nvidia card too without a hitch. ATI cards are a bit of a pain to install.
#13 (permalink) |
do you have fedora installed just go to the menu which controls the services..
or if u like terminal: Code:
~#system-config-services Linux is not for geeks...just that the *NIX systems want the user too be sensible I too laughs at one of my younger friend who finds Nirvana in obtaining cracks and warez illegal items and saying Windows is gr8
#14 (permalink) |
Try me
@praka123 right now i am at hospital and with my lappy and only have windows.. but i noted down the command what you wrote and will surely try it, Thanks to you for the info.
and why MODS have turned off the reutation
#15 (permalink) | |||||
One thing that I didn't mention was the fact that the problem started after installing lots (about 13 GB) of software.
"Couldn't connect DCOP signal. Won't receive any status notifications!" I searched and found that it has something to do with kdesvn. So, I uninstalled it. The problem hasn't appeared after that. Quote:
#16 (permalink) |
Check if you aren't running out of disk space. And also do a memtest to see if it isn't a problem with RAM.
#17 (permalink) |
and you do have a swap partition?@least 600 MB
#18 (permalink) | ||
Problem solved
What happened was that I had installed Kubuntu just before the problem appeared. I had chosen the same swap partition that I had been using for Mandriva for Kubuntu also. During installation, Kubuntu said that /boot, / and swap partitions must be formatted, I said yes, and the installation went fine. Then I booted into Mandriva and the rest you know. Mandriva had fstab entry for swap as LABEL=SWAP-hdb7 swap swap 0 0. When Kubuntu formatted it, the label was changed to linux-swap. I changed the fstab entry to /dev/hdb7 swap swap 0 0 and everything is fine now. I am still wondering, when I did 'top', why I didn't notice the entries next to 'swap' that said '0 total, 0 used & 0 free'. I looked at only the last entry which always say 200-700 MB cached. This might have given me the feeling that swap is there. A check of /var/log/syslog revealed that kernel had killed kdeinit and kwin because of out of memory, which explains why KDE crashed. Thank you guys very very much for helping me solve this. |
#21 (permalink) |
If you are talking about me using Malayalam here, sorry. Since the purpose of this thread was over, I thought there wouldn't be anything wrong. What I meant was "Thanks for spreading the light". In Malayalam, 'prakasham' means 'light'. The second word means 'to spread', and the third means 'thanks'. But, if you were thinking what I have just realized after reading my post from your quote, *no*. I didn't have any such intentions
For non-malayalam members: it can also be read with a different Malayalam pronunciation, in which case the meaning become 'to scratch' |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
