Old 20-02-2007, 07:49 PM   #1 (permalink)
devilzdad's Avatar
Question Pro with ubuntu...??
Yesterday i tried to upgrade my ubuntu 5.10 to 6.06 using the software update manager.When i rebooted my PC i was not able to use GNOME display..... its showing dat there is some pro with xserver. So i used the following command :
sudo dpkg-reconfigure xserver-xorg
But dis didn't solve my pro.... and while booting there was some error in starting and configuring PCMCIA services........
so guys plz help me to solve dis pro..
devilzdad is offline
Old 20-02-2007, 08:21 PM   #2 (permalink)
18 Till I Die............
Default Re: Pro with ubuntu...??
Looks like the upgrade wasn't clean maybe. But, first if you can give us the proper error then someone will be able to help out better.
http://www.bash.org/?258908
mehulved is offline
Old 20-02-2007, 08:49 PM   #3 (permalink)
Debian Rocks!
freebird's Avatar
....also post ur hardware details like GFX card used..
"The day windows users wake up to reality, it will be doomsday for Microsoft."UNIX like OS are more secure.get urself out 4m M$ http://whylinuxisbetter.net http://tinyurl.com/2amjjc http://fsf.org
freebird is offline
Old 20-02-2007, 10:21 PM   #4 (permalink)
devilzdad's Avatar
I got the following errors while loading modules:
starting PCMCIA services..........failed
waiting for n\w interface to come up.........failed
Then it showed fail to start xserver......... then i used the command
sudo dpkg-reconfigure xserver-xorg ......... to configure xserver ....... still i was not able to use GUI....... i can use only in command mode......
BTW my GFX card is intel 82845 G/GL/GE/PV graphics controller.....
Old 20-02-2007, 10:40 PM   #5 (permalink)
Also give the output of uname -r
It happened to me while updating to 6.10, that kernel wasn't updated so there were many problems, like xserver not starting and network interface also could not start.
mehulved is offline
Old 20-02-2007, 11:56 PM   #6 (permalink)
El mooooo
eddie's Avatar
Yup it is either a kernel or init problem. Looks like xorg is unable to find DRI modules and fails to start.
eddie is offline
