Old 20-02-2007, 08:53 AM   #1 (permalink)
Default HP 610c issues
i cant seem to find my 610c with System>Administration>Printing
i added hplip/foomatic-gui/cups.. still ubuntu edgy eft 64 cant scan for any visible printers.. and yes my printer is sqitched ON during all these times..
any help will be greatly appreciated
da_tcpip is offline
Old 20-02-2007, 11:40 PM   #2 (permalink)
El mooooo
eddie's Avatar
Default Re: HP 610c issues
Did you restart CUPS (or reboot system) after installing those packages? hplip comes with hp-setup program for installing new printers. Try executing it from a terminal window and see if it finds the printer. If it still doesn't find the printer then try removing your USB cable from your cabinet and reinsert it. Then try again.
eddie is offline
Old 21-02-2007, 08:17 AM   #3 (permalink)
yes i have restarted the system many a times.. even ran hp-setup but it cant see any printers.. and 610c connects to the lpt port
da_tcpip is offline
Old 21-02-2007, 12:21 PM   #4 (permalink)
El mooooo
eddie's Avatar
Oh I didn't realise it was a parallel printer...but then again...you didn't mention it
Anyways, non detection of parallel printers is a known bug introduced in Dapper (6.06) and carry forwarded to Edgy (6.10). It is solved for Fiesty and in latest packages of CUPS for the previous releases of Ubuntu. You need to update your repositories and install the newer packages of CUPS manager.
A workaround would be to modify your /etc/modules file and remove "lp" module from it. Restart your system and the printer should be detected.
eddie is offline
Old 21-02-2007, 09:56 PM   #5 (permalink)
thanks a lot eddie.. your workaround worked.. btw is it necessary to enable that module again??
da_tcpip is offline
Old 21-02-2007, 10:26 PM   #6 (permalink)
El mooooo
eddie's Avatar
Actually in order to get printers with parallel ports working, cupsys loads lp module at its startup. In earlier versions of Ubuntu, the module was loaded at boot up and then cupsys tried to load it again but since the module was already loaded...cupsys failed. This confused cupsys and it did not detect printers connected to parallel port. Now since you have disabled loading of the module at boot up...the module is being successfully loaded by cupsys so you don't need to enable it
eddie is offline
