Old 17-02-2007, 11:45 AM   #1 (permalink)
eagle_y2j's Avatar
Cool How to add VISTA's boot entry to GRUB
I am running Open Suse 10.2 ,installed after installing MS Vista (ultimate) but i can't see boot entry of Vista in GRUB ? How to add that in my case Vista is on primary partion hda5 .
TIA
Registered LINUX USER #438929
eagle_y2j is offline
Old 17-02-2007, 12:26 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: How to add VISTA's boot entry to GRUB
well open suse detected my vista as a windows os n added its boot entry automatically...
Pathik is offline
Old 17-02-2007, 12:29 PM   #3 (permalink)
MMO Addict
amitava82's Avatar
did u try this method posted here: Vista and GRUB
Steam Profile || Personal Page
Warp drive active. Approaching stargate.
amitava82 is offline
Old 17-02-2007, 02:09 PM   #4 (permalink)
eagle_y2j's Avatar
tried but no sucess
Old 17-02-2007, 09:18 PM   #5 (permalink)
Debian Rocks!
freebird's Avatar
Post Re: How to add VISTA's boot entry to GRUB
TIA
as root edit the file /boot/grub/menu.lst and save:
at the end of the file.
title           Microsoft Windows Vista Ultimate
root            (hd0,4)
savedefault
chainloader     +1
you can use any editors like gedit as root user to save it.try at "$" prompt
~$gksu gedit  /boot/grub/menu.lst
"The day windows users wake up to reality, it will be doomsday for Microsoft."UNIX like OS are more secure.get urself out 4m M$ http://whylinuxisbetter.net http://tinyurl.com/2amjjc http://fsf.org
freebird is offline
Old 18-02-2007, 12:54 PM   #6 (permalink)
eagle_y2j's Avatar
I tried editing /boot/grub/menu.lst from YAST control panel but each time i am saving
root            (hd0,4)
savedefault
chainloader     +1
there it automatically changes into
    rootnoverify (hd0,0)
    savedefault
    chainloader (hd0,4)+1
Old 18-02-2007, 02:26 PM   #7 (permalink)
18 Till I Die............
Just try editing it manually.
http://www.bash.org/?258908
mehulved is offline
Old 18-02-2007, 04:09 PM   #8 (permalink)
eagle_y2j's Avatar
tried
# edit /boot/grub/menu.lst
but how to insert new data and how to save in root mode
Old 18-02-2007, 04:18 PM   #9 (permalink)
desertwind's Avatar
Already answered by freebird.
$ gksu gedit /boot/grub/menu.lst
Sometime you'll think you understand everything
...Then you'll regain consciousness
desertwind is offline
Old 18-02-2007, 06:00 PM   #10 (permalink)
MMO Addict
amitava82's Avatar
it should be like this (if you have single HDD and Vista is installed in C drive):
open console, type:
remove your existing windows entries n replace with this:
title windows Vista
root (hd0,0)
makeactive
savedefault
chainloader +1
Old 18-02-2007, 06:57 PM   #11 (permalink)
eagle_y2j's Avatar
bash: gksu: command not found
Old 18-02-2007, 07:02 PM   #12 (permalink)
gksu is found in gnome. That means you've not install gnome. For KDE there's kdesu
mehulved is offline
Old 18-02-2007, 07:14 PM   #13 (permalink)
eagle_y2j's Avatar
thankx for this but now it says kdesu can't connect to X server ?
Old 18-02-2007, 07:24 PM   #14 (permalink)
Debian Rocks!
freebird's Avatar
do one thing Press ALT+F2 to get a run dialog.then enter those commands in run dialog and press enter-run.
u cant sometimes invoke gksu from terminal ;that is a whole another thing. "xhost +" to disable acl may help.
freebird is offline
Old 18-02-2007, 07:27 PM   #15 (permalink)
eagle_y2j's Avatar
ok after googling i found this
kdesu kwrite /boot/grub/menu.lst
Old 18-02-2007, 07:28 PM   #16 (permalink)
Debian Rocks!
freebird's Avatar
oh u use kde
freebird is offline
Old 18-02-2007, 07:36 PM   #17 (permalink)
eagle_y2j's Avatar
Added following to menu.lst sucessfully
title windows Vista
root (hd0,4)
makeactive
savedefault
chainloader +1
but getting following error
Booting Windows Vista
root (hd0,4)
filesystem type unkown,partition type 0 X 7
makeactive
Error 12 :Invalid device requested .....
Press any key to continue.....
Old 18-02-2007, 07:51 PM   #18 (permalink)
Debian Rocks!
freebird's Avatar
that error means u have not having win partn as hda5.check again where u have ur windows partn using fdisk:
~#fdisk  -l
I mean post the output
freebird is offline
Old 18-02-2007, 07:53 PM   #19 (permalink)
desertwind's Avatar
Are you sure that Vista is intalled on hda5?
Can you post the output of the following command
$ sudo fdisk -l
Old 18-02-2007, 08:00 PM   #20 (permalink)
eagle_y2j's Avatar
system:/media/hda5 is my Vista's hdd partition and can't figure out above commands
sudo: fdisk: command not found
Old 18-02-2007, 08:20 PM   #21 (permalink)
Debian Rocks!
freebird's Avatar
try
$ su -
(give ur root passwd)
now at "#" prompt :
~#   /sbin/fdisk -l
now post the o/p.
freebird is offline
Old 18-02-2007, 08:24 PM   #22 (permalink)
eagle_y2j's Avatar
k here is the output:-
Disk /dev/hda: 40.0 GB, 40020664320 bytes
255 heads, 63 sectors/track, 4865 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Device Boot Start End Blocks Id System
/dev/hda1 * 1 2434 19551073+ 83 Linux
/dev/hda2 2435 4865 19527007+ f W95 Ext'd (LBA)
/dev/hda5 2435 4788 18908473+ 7 HPFS/NTFS
/dev/hda6 4789 4865 618471 82 Linux swap / Solaris
Disk /dev/hdb: 80.0 GB, 80026361856 bytes
255 heads, 63 sectors/track, 9729 cylinders
/dev/hdb1 2 9729 78140160 f W95 Ext'd (LBA)
/dev/hdb5 2 4875 39150373+ b W95 FAT32
/dev/hdb6 4876 9729 38989723+ b W95 FAT32
linux-nrn0:/home/loveme #
Old 18-02-2007, 08:32 PM   #23 (permalink)
Debian Rocks!
freebird's Avatar
you may have ur windows on second hdd?that's a possibility na?
anyways,try once more editing /boot/grub/menu.lst
as :
root            (hd1,4)
savedefault
chainloader     +1
try.....
freebird is offline
Old 18-02-2007, 08:36 PM   #24 (permalink)
change root to rootnoverify in menu.lst
mehulved is offline
Old 18-02-2007, 08:50 PM   #25 (permalink)
drsethi's Avatar
I am having similar problem
I have Windows XP SP2 on hda1
Windows vista beta on hda8
Suse 10.2 on hda 10.
I can boot XP and Suse but not vista by any means.
Menu.lst entries are as follows
default 0
timeout 8
gfxmenu (hd0,9)/boot/message
###Don't change this comment - YaST2 identifier: Original name: linux###
title openSUSE 10.2
root (hd0,9)
kernel /boot/vmlinuz-2.6.18.2-34-default root=/dev/sda10 vga=0x317 resume=/dev/sda9 splash=silent showopts elevator=
initrd /boot/initrd-2.6.18.2-34-default
###Don't change this comment - YaST2 identifier: Original name: windows###
title Windows XP
chainloader (hd0,0)+1
###Don't change this comment - YaST2 identifier: Original name: failsafe###
title Failsafe -- openSUSE 10.2
root (hd0,9)
kernel /boot/vmlinuz-2.6.18.2-34-default root=/dev/sda10 vga=normal showopts ide=nodma apm=off acpi=off noresume nosmp noapic maxcpus=0 edd=off 3
Please tell me what should be entered in Menu.lst or elsewhere so I can boot Vista as well.
drsethi is offline
Old 18-02-2007, 08:55 PM   #26 (permalink)
drsethi you should try the same too. Change root to rootnoverify for vista.
mehulved is offline
Old 18-02-2007, 08:57 PM   #27 (permalink)
eagle_y2j's Avatar
drsethi %%%bumped ...
tried
root            (hd1,4)
savedefault
chainloader     +1
also tried rootnoverify (hd1,4)
getting continous beeps with following error
root (hd1,4)
filesystem type is fat,partition type 0 X b
safedefault
chainloader +1
Old 18-02-2007, 09:05 PM   #28 (permalink)
it's hd0,4 not 1,4
mehulved is offline
Old 18-02-2007, 09:18 PM   #29 (permalink)
left this forum longback
praka123's Avatar
@eagle_y2j
does it worked?the soltn 4m tyf.if not try to add "makeactive" also..
rootnoverify    (hd0,4)
makeactive
chainloader     +1
praka123 is offline
Old 18-02-2007, 09:30 PM   #30 (permalink)
Debian Rocks!
freebird's Avatar
try this since u have vista on a non-primary partn(hda5) afaik.this make Vista to belive its installed on primary partn.this may be the soltn
 title Windows Vista
rootnoverify (hd0,5)
map (hd0,0) (hd0,5)
map (hd0,5) (hd0,0)
makeactive
chainloader +1
M$ wants their OS to be the only one installed on ur disk..
freebird is offline
