Old 12-02-2007, 05:08 PM   #1 (permalink)
Resident Fanatic
Manshahia's Avatar
Default Linux Software Problems
I downloaded soe softwares with tar.gz format.
Unpacked them using tar -zxvf .....tar.gz
Now how can i run them ??
Manshahia is offline
Old 12-02-2007, 05:16 PM   #2 (permalink)
Call me Sumit
esumitkumar's Avatar
Default Re: Linux Software Problems
There will be a readme with theb folder..read it ..how to install
1.Open terminal
2. go to the desired directory like /root/desktop/xmms
3. Type commands like
$ make
$ make install
$ ./xmms
or sometimes ./configure before make
esumitkumar is offline
Old 12-02-2007, 07:52 PM   #3 (permalink)
Resident Fanatic
Manshahia's Avatar
Copied a software from Digit DVD in same format
Unpacked that, but cudnt find any configure, make files in that.
I think the software is preinstalled.
Old 12-02-2007, 08:12 PM   #4 (permalink)
18 Till I Die............
Read this first How To Ask a Question Here
Then tell us the name of the software. And there will be a README file in there, read it.
http://www.bash.org/?258908
mehulved is offline
Old 12-02-2007, 08:34 PM   #5 (permalink)
Resident Fanatic
Manshahia's Avatar
^^ Read that.
There's no read me in the Folder.
The software's name is Flock-a Web rowser.
Also i downloaded win32 codecs in RPM format.
Ran this rpm -ivh ******.rpm
everything went fine. Now where r the Codecs or they got embedded in the applications that need them??
Old 12-02-2007, 08:40 PM   #6 (permalink)
I don't think you will have to compile flock. Just place it in a folder, like /usr/lib or something and create a shortcut to the flock executable.
win32codecs are generally installed in /usr/lib/win32.
mehulved is offline
Old 12-02-2007, 09:03 PM   #7 (permalink)
Resident Fanatic
Manshahia's Avatar
How do i knw that i dont need to compile a software or not to ??
How to figure out which is the software's executable?
Old 16-02-2007, 04:26 PM   #8 (permalink)
Resident Fanatic
Manshahia's Avatar
I downloaded a software Knemo.
Unpacked the Tar using the command
tar -xvf 12956-knemo-0.4.6.tar.bz2
When i gave command
./configure
It started doing something with files like in Matrix[]
After some time it gave this error
configure: error: Can't find X includes.
Please check your installation and add the correct paths!
Wats the problem??
Old 16-02-2007, 04:41 PM   #9 (permalink)
Why can't you use the package manager?
mehulved is offline
Old 16-02-2007, 04:53 PM   #10 (permalink)
Resident Fanatic
Manshahia's Avatar
Where is it ??
Cudnt find any package manager in the menu.
Old 16-02-2007, 05:44 PM   #11 (permalink)
Beneath The Eyelids
The Outsider's Avatar
Yast in opensuse and Synaptic Manager in Ubuntu, must be there
The Outsider is offline
