Old 21-01-2005, 04:21 PM   #1 (permalink)
Default help in linux
How Can i auto mount my fat32 drive in redhat 9?
can i mount NTFS ? how?
And Can any one help me to learn perl?
vipul is offline
Old 21-01-2005, 06:32 PM   #2 (permalink)
Yeah, look at the fat32 partitions using fdisk....and then add them to the /etc/fstab file.
type "auto" as the parameter...to mount them everytime..your system boots
As far as perl is concerned, there are some man pages available there in Linux...but you can always get a book.
For mounting NTFS partitions..you have to install a small program..that patches up the kernel for NTFS support. Try google.
ankursmart is offline
Old 21-01-2005, 09:52 PM   #3 (permalink)
You can replace the word 'c' with any word you like.
Open a console (terminal), log in as root ('su' command) and type:
mkdir /mnt/c
This will create the folder 'c' in the /mnt directory where your fat partition will be mounted.
mount -t vfat /dev/hda1 /mnt/c
Million's Of Open Minds Can't Be Wrong!
http://nc.xmgfree.com/weblog
Everybody Wants to go to Heaven...But nobody wants to Die!
naveenchandran is offline
