Old 05-02-2007, 11:21 PM   #1 (permalink)
sam_1710's Avatar
Unhappy Suse 10.1 - Display server problem!!
I installed suse 10.1 on my pc wid Pentium D - 2.8GHz, 1GB RAM, 7600GT card... and when i select the os from the grub screen, it loads for sometime and the display gets cut and i have to press [ctrl]+[shift]+[backspace], where im shown this error message : "Display server shutdown ... " ..
click here for a screenshot.
sam_1710 is offline
Old 06-02-2007, 06:59 AM   #2 (permalink)
18 Till I Die............
Default Re: Suse 10.1 - Display server problem!!
Which driver are you using for video card?
http://www.bash.org/?258908
mehulved is offline
Old 06-02-2007, 10:02 AM   #3 (permalink)
sam_1710's Avatar
not yet installed any driver... installed suse and even before the 1st boot im gettin this error!!
sam_1710 is offline
Old 06-02-2007, 10:05 AM   #4 (permalink)
Google Bot
Pathik's Avatar
i think u need to edit ur xorg.conf and specify display driver as vesa..
Pathik is offline
Old 06-02-2007, 10:06 AM   #5 (permalink)
sam_1710's Avatar
how do i go bout doing that??
sam_1710 is offline
Old 06-02-2007, 11:52 AM   #6 (permalink)
I guess suse maybe using nv driver for your card.
For editing xorg.conf type this command after logging in as root
nano -w /etc/xorg.conf
Then you will find something like this
Section "Device"
Driver "nv"
End Section
replace nv or whatever there is with vesa, if it's already vesa then use nv and try.
mehulved is offline
Old 06-02-2007, 02:33 PM   #7 (permalink)
sam_1710's Avatar
i cant find 'xorg.conf' .in the etc directory...
when i hit "nano -w /etc/xorg.conf" .. a new file opens (logged in as the root) !!
wat do i do??
sam_1710 is offline
Old 06-02-2007, 02:45 PM   #8 (permalink)
Oops very sorry, it's /etc/X11/xorg.conf
mehulved is offline
