Old 30-01-2007, 05:33 PM   #1 (permalink)
"The RaCaLaNGeL"©
romeo_8693's Avatar
Exclamation mounting problem in DSL
i installed dsl on my pen drive.the problem is i cant mount my hard disk wic has one ext3 file sys and another ntfs.i want to know how can i mount both these drives wen i boot thru pen drive in dsl.
Without sorrows happiness would be boring!
romeo_8693 is offline
Old 30-01-2007, 06:09 PM   #2 (permalink)
18 Till I Die............
Default Re: mounting problem in DSL
There are so many threads on it. Just bother to search once atleast.
Here's how to do it
sudo mkdir /mnt/windows /mnt/linux
sudo mount -t ext3 /dev/hda3 /mnt/linux
sudo mount -t ntfs /dev/hda1 /mnt/windows
replace /dev/hda3 by whatever your linux partition is, similarly /dev/hda1 by whatever your ntfs partition is. ntfs partition will be mounted read only.
If you don't know check the output of
sudo fdisk -l
http://www.bash.org/?258908
mehulved is offline
Old 31-01-2007, 03:23 PM   #3 (permalink)
"The RaCaLaNGeL"©
romeo_8693's Avatar
thanx 4 info but i know that!it givs some error with /dev/hda!!
btw does DSL support ntfs by default?
Old 31-01-2007, 03:30 PM   #4 (permalink)
you can't mount /dev/hda cos it's the whole hard disk. You can only mount partitions.
mehulved is offline
Old 31-01-2007, 03:42 PM   #5 (permalink)
"The RaCaLaNGeL"©
romeo_8693's Avatar
wat abt ntfs support?
Old 31-01-2007, 03:48 PM   #6 (permalink)
I don't know, since I haven't used it. But searching in thier forum suggests ntfs read support is enabled.
mehulved is offline
Old 31-01-2007, 04:10 PM   #7 (permalink)
"The RaCaLaNGeL"©
romeo_8693's Avatar
probably the never version.even i read so....but i cant download it...so i want to modify this one only
Old 02-02-2007, 10:56 AM   #8 (permalink)
"The RaCaLaNGeL"©
romeo_8693's Avatar
its done...thanks!
__________
its done...thanks!prob was with using hdb rather than hdb5
Old 02-02-2007, 07:56 PM   #9 (permalink)
That's what I said in 4th post. What you were trying to do is mount the full disk. You can only mount partitions. Even if there is only one partition on the disk, you can only mount that partition not the whole disk.
mehulved is offline
