Old 25-01-2007, 06:56 PM   #1 (permalink)
Adhip007's Avatar
Exclamation PLz HELP! FC 6 couldn't detect sata Hdd
Hi,
I have following config:
Intel Core2duo E6300 cpu,
Asus P5b M/B,
Hitachi 200 gb sata hdd,
512 mb DDr2 ram,
Geforce 7900gs ,
LG DVD writer
I have windows XP and Mandriva 2007 installed.
While installing FC6 it couldn't detect the hard drive, so installation could not be completed.
Also the Mandriva2007 didn't detect the DVD writer.
Please help
Thanks in advance
Adhip
My new Config: Phenom II X6 1100T + ASUS M5A88M + Palit GTX 260 + 4GB Ram(Corsair Vengeance) + 200 GB(Hitachi) + 500 GB(Seagate) SATA+ 1TB external(Seagate) + Corsair VX550 W Smps.
ACER TravelMate 4740
http://www.flickr.com/photos/adhip_ghosh/
Adhip007 is offline
Old 25-01-2007, 07:00 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: PLz HELP! FC 6 couldn't detect sata Hdd
fc6 has no probs wit sata now.. It shd work..
Pathik is offline
Old 25-01-2007, 07:05 PM   #3 (permalink)
Adhip007's Avatar
No it didn't work I shows no hdd at the time of partitioning
Adhip007 is offline
Old 25-01-2007, 09:46 PM   #4 (permalink)
El mooooo
eddie's Avatar
Have you used Fedora 6 or Fedora 5? Your motherboard is quite new and has been reported to work with Fedora 6 only. If it does not work then I am sorry to inform you but you will have to compile a custom kernel
eddie is offline
Old 25-01-2007, 11:03 PM   #5 (permalink)
Adhip007's Avatar
I have used mandriva 2007, but not fc6 in this motherboard. But I think Mandriva 2007's kernel is older than FC6 (zod)
Adhip007 is offline
Old 26-01-2007, 08:44 AM   #6 (permalink)
Let the music play.....
djmykey's Avatar
Ok Adhip007 now go to your BIOS and check the mode that SATA is working in there is a Combination and another mode whose name I dun remember. Remove it from combination if you can find it. FC has some problems with that mode. So remove that setting and FC will detect your hard disk allright.
djmykey is offline
Old 29-01-2007, 04:58 PM   #7 (permalink)
Adhip007's Avatar
@djmykey
I have Set SATA as IDE mode
BIOS has only two mode one ahci & IDE
Adhip007 is offline
Old 30-01-2007, 07:30 PM   #8 (permalink)
El mooooo
eddie's Avatar
If it worked with Mandriva then try installing Fedora in text mode and note down the error at which it stops. This will help us in guessing the reason behind the non-detection of HDDs
eddie is offline
Old 01-02-2007, 07:33 PM   #9 (permalink)
The Devil
blackpearl's Avatar
What the hell!! FC6 is not detecting my Sata drive too.
Stupid developers.
blackpearl is offline
Old 01-02-2007, 08:42 PM   #10 (permalink)
baccilus's Avatar
FC6 doesn't detect my LAN card. It detects it wrongly which obviously doesn't work. It doesn't detect realtek cards i think
Appreciate me now and avoid the rush!!
i5 2500K || 8GB DDRIII 1600 MHz RAM || Zotac GTX560Ti || Samsung 2233sw || Corsair GS600
baccilus is offline
Old 03-02-2007, 06:50 PM   #11 (permalink)
Adhip007's Avatar
Changing the settings from enhanced to compatible in Bios FC6 does detects HDD in text mode booting. but still not able to install it. It doesn't shows the hdd in partitioning screen
Adhip007 is offline
