Old 23-01-2007, 09:26 PM   #1 (permalink)
Fedora User
LEARNER_LEARNER's Avatar
Post Beryl Problem.
Hi brother,when i started bery then bery goes on taskbar but my problem is when i try to do changed "select windows manager" nd click on bery option then msg came "The Composite Manager Crased twice within a minute nd is therefore disabled for this session."
what is problem?.please help brother.
i'm waiting 4 your reply..
LEARNER_LEARNER is offline
Old 23-01-2007, 10:12 PM   #2 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Default Re: Bery Problem.
Which distro are you on?
kalpik is offline
Old 23-01-2007, 10:28 PM   #3 (permalink)
Just another linux lover.
subratabera's Avatar
The graphic card is not supported...Are you using via chipset? Try to update your graphics card drivers...Check your /etc/X11/xorg.conf file...
Today is a most unusual day, because we have never lived it before; we will never live it again; it is the only day we have.
(Registered Linux User #432737 - subratabera.blogspot.com)
subratabera is offline
Old 23-01-2007, 10:29 PM   #4 (permalink)
Fedora User
sorry 4 not mention distro,My distro is FC6 .My laptop Dell 640 brother,nd bery nice work in root but when i trying 2 activate in my user account(LEARNER) then msg coming brother.
Old 23-01-2007, 10:42 PM   #5 (permalink)
Open your home folder and press ctrl+h to view hidden files and folders...Now delete all beryl/emerald related files and folders...Then logoff...login...Restart beryl...
Old 24-01-2007, 12:04 AM   #6 (permalink)
String Phreak
mediator's Avatar
^^+update beryl.
mediator is offline
Old 24-01-2007, 08:20 AM   #7 (permalink)
kalpik's Avatar
If you are using KDE, disable taskbar transparency.
kalpik is offline
Old 24-01-2007, 04:34 PM   #8 (permalink)
Fedora User
Default Re: Beryl Problem.
Hi thanX 4 help brother but another problem is bery start work fine but when i shutdown my laptop nd start again but bery is not starting automatically.ok
Then i every time start from Sytem Bery Manager>click on bery icon(Taskbar)>Select Windows Manager>nd click on bery option.
Lots option in bery ,please help brother nd i am using KDE.
please help brother
